05-07-2011, 06:31 AM
Member #5638
Rear Suspension Articulation
I have a 2003 Sportsman 700 that the rear wheels are always slanted in at the top and out at the bottom. A Polaris mechanic said the shocks were good but I know the wheels should run vertical. Bought it used, so it may have wrong shocks or some other problem. Anyone got any ideas. Thanks in advance.
05-07-2011, 06:50 AM
Member #11470
i think the shocks are set on the lowest setting turn them up and see if that helps
o8 sprotsman 500
05-07-2011, 07:52 AM
05-07-2011, 07:56 PM
Member #10159
My 01 runs that way also. Give Utah's idea a try.
2011 Sportsman Touring 850  (current)
2006 Outlander 400 (Sold)
2001 Sportsman 500HO (Current)
1997 Explorer 500 (Traded)
1998 Sport 400. (Sold)
1994 Trailblazer. (Sold)
198? Suzuki Quadsport 230. (Sold)
197? Yamaha YZ225 Three-Wheeler (Traded)
05-07-2011, 11:45 PM
Member #7117
I dont really know what the shocks have to do with this problem. It doesn't matter what shocks you have or what condition they are in the rear should be at or near 0 degrees through its entire range of motion. What your describing is negative camber http://www.jackit.com/bushings/image...xplanation.jpg
A few things could cause it.
Very worn A-arm bushings
Very worn wheel bearings
Very worn ball joints (front only)
Or worst case mechanical damage like a bent frame or A-arms.
05-08-2011, 05:58 AM
Member #5629
Welcome!
From your description, you have some sag in the rear end.
To solve this, most people install HD springs.
There are several springs that will work, all depending on how stiff you want the bike to ride.
Con
05-08-2011, 06:34 AM
Member #7044
Your Rear wheels are like this / \, I can honestly say I've never seen a
Sportsman with the rear wheels on an angle from the atv's I've seen so
far. What size tires are on the back?
Take care,
Scott Deeter
05-08-2011, 02:58 PM
Member #7117
Originally Posted by Thomasj
I dont really know what the shocks or springs have to do with this problem. It doesn't matter what shocks you have or what condition they are in the rear should be at or near 0 degrees through its entire range of motion. What your describing is negative camber http://www.jackit.com/bushings/image...xplanation.jpg
Again
05-08-2011, 04:02 PM
Member #1634
Again
you are right no matter the range of motion the tires should be straight up and down. the shocks simply will keep the machine up higher if adjusted, not change the camber
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
05-10-2011, 03:10 PM
Member #5638
Wheel articulation and slant
Thanks to all that posted tips and suggestions. I am currently running AT 26 X 11-12 Mud Boss tires on the ATV. The suggestion about shock position worked very well. There is some wear in the bearings or axles but by changing the shock position the wheels straightened considerably.
Again thanks to everyone. Great site and resource.
06 sportsman 800 rear bushings, 2003 polaris sportsman 700 rear sag, 2007 sportsman 500 suspension, 800 sportsman rear tire tilt, 98 polaris sportsman 500 4x4 rear bushings, left rear suspension appears bent, left rear tire on sportsman 1998 500 looks bent, negative camber left rear wheel 800 sportsmen, polaris atv back wheel slanted, polaris rear tires tilted in, polaris sportsman 500 rear tire at angle, polaris sportsman 700 twin rear wheel tilted, polaris sportsman rear suspension, polaris sportsman suspension is worn out, polars rear wheels slant in, see how to adjust springs in rear end on sportsman 500 1997, suspension articulation, what is suspension articulation, why is camber on polaris set at, wrong a arm rear sportsman
