05-14-2011, 10:45 AM
Member #15041
Trailblazer 250 can't get compression...
Hi Everyone. I have a 2000 Trailblazer 250 I am having compression problems with. New piston & rings (gap is .010) clean honed bore from machine shop, and rings seem to be tight all the way around. All I can get is 60 psi on a gauge and it will hold it for a day with no pressure loss. No visible cracks or damage on head. Any ideas or something else I can try?? Thanks!
05-14-2011, 10:58 AM
Member #14439
wrong head gasket?
05-14-2011, 11:21 AM
Member #15041
It looks right and fits the motor. How else could you tell?
05-14-2011, 11:38 AM
Member #14439
Thickness of it could be off. If you are relatively sure the piston and rings are correct, the only other thing that could effect the compression is the head and gasket. Sounds like your leak down test was great.
Was your compression tester fairly reliable til this test?
05-14-2011, 08:52 PM
Member #15041
Trailblazer leak down test...?
Ok, so I read another link on how to do a leak down test on my 2000 model 250. Evidently it was only my gauge that was holding pressure! Duh!! So, I capped exhaust and intake , then put air to it, and air started coming out around the magneto wires!?! Should the crankcase be pressurized?? or... do I have another problem? Rings not sealing? Thanks for any help!
05-15-2011, 08:20 AM
Member #14439
yes the crank case is going to be pressurized, this helps find the leaks it seems you may have. Best thing to do after having done a 2 stroke rebuild. helped me find a small leak on mine I never would have found otherwise.
$17 Leak Tester (2-Stroke)
Sounds like you may have a crank seal leak, if the stator wires are where I think they are. I know when you do the pressure test on my engine, the piston is to be in the down position. Hope this helps.
05-15-2011, 08:34 AM
Member #15041
Thanks gear head! That is actually the link I found and built my tester from! A crank seal leak, huh? So... will that affect / be the cause of the low compression? Thanks again!
05-15-2011, 12:37 PM
Member #14439
I gotta be honest, I don't think that would cause low compression, however can cause disaster for the engine and cause problems for you. I personally believe the compression would be an issue with piston and above.
Hopefully someone will chime in and help a little here.
05-16-2011, 04:20 AM
Member #7294
With a new piston and rings and hone job you will not get real good compression until those parts break in a bit, are you able to get it started and yes if air is leaking out around stator wires youn have a seal leaking.
01-13-2012, 06:08 PM
Member #22272
Wolf trail,
I need your help. I just had my friends blazer bored and honed and it now has 62 psi compression. What was your solution? Thanks,
Rob
2000 polaris trail blazer piston, 2000 polaris trailblazer 250 problem, 2000 polaris trailblazer 250 specs, 250 polaris ring gap, bad compresion on 05 polaris trailblazer, compression gap rings seat polaris atv, compression spec 2000 polaris 250, compression/polaris trailblazer 250, head gasket on polaris trailblazer, how to replace low compression polaris trailblazer250, polaris 250 compression, polaris 250 low compression, polaris 250 minimum compression, polaris 250 trail compression, polaris trailblazer 250 compression, polaris trailblazer 250 compression specs, polaris trailblazer 250 specs, polaris trailblazer compression , polaris trailblazer pressure test, what should be the compression be polaris 250 trailblazer
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
compression
sks1 |
ATV Repair and Maintenance |
3 |
03-25-2011 06:36 PM |
Low Compression
flatlandr |
7 |
03-12-2011 05:16 PM |
Low compression
Mitchell |
Polaris Sportsman |
2 |
04-29-2010 10:30 AM |
Compression
Stevehi |
Polaris Trail Blazer |
2 |
04-17-2010 02:19 PM |
No compression
chewy1010 |
1 |
10-29-2009 08:52 AM |
