Old 05-22-2011, 01:09 PM
skizmo's Avatar
Member #13773
please help!!!...rotors/disk brakes
as a newbie, this may sound dumb or its really a problem...just got home from riding and i am in the process of cleaning my bike..I noticed that there is no rotor on the rear left tire..???is this correct...the other 3 wheels have rotors..this is a quote from the specs of my bike... "Front/Rear Brakes: Single Lever 4-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake
Parking Brake: Park in Transmission/Lockable Hand Lever"
can some please explain to me b4 i ride again tomorrow..if this is correct..The way i take that is that there are 4 disc brakes....does that mean that there would be 4 rotors????...because i only have 3....and maybe this is the coz of my front brakes needing replacement at 10 hrs...
Get Some!
2011 Sportsman 550 XP Camo
ATV Logic Rear Storage Pack
Fin Grip Gun And Bow Holder
Custom 2-Up Seat
Pure Polaris Hand Guards
27' Swamp Lights
Polaris Front Lock&Ride Box
Ricochet A-Arm Guards (Black)
ATV Superstore 3 way Hitch
Garmin GPSmap 62
Old 05-22-2011, 01:11 PM
cwlongshot's Avatar
IIRC the 850 is the only model with a brake at each wheel... All the rest only have three. In an effort to better protect the brakes they put it inside the one wheel.
Your just fine...
If your brakes are worn out after ten hours...your going too slow or not riding enough... Remember brakes are for stopping.
Old 05-22-2011, 01:23 PM
skizmo's Avatar
Member #13773
sorry cw...im not quite sure i understand...so on my fourth wheel the rear left...the brake is in the wheel??....because theres no steel brake line running to that wheel/no rotor/no pads/nothing that i can see would act as a brake.like the right wheel......and what your saying is I only have three brakes not four?????why does it say in the specs for 550..that you have..... Front/Rear Brakes: Single Lever 4-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake
hence the 4 wheel hydraulic disk...i only see 3...im sorry i juss dont get it..and all my gear head friends are gone for the weekend......thanks cw
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
Old 05-22-2011, 01:32 PM
cwlongshot's Avatar
That's correct, you only have three and that's the way it was built and designed.
Think on older different make quads... almost 100% had only three brakes. Two front and one rear. The independent rear and "car like" feel and design of the Sportsman is throwing you.
Your rear axle is locked, one side is identical in rotation to the other, so one brake will equally stop both rear tires.
Old 05-22-2011, 01:34 PM
MNPolaris850XPeps's Avatar
Member #11395
the only way an xp has 4 brakes is if its a 2009
POLARIS 850 XP W/EPS pure polaris hand guards and front lock and ride box, RICOCHET front and rear a-arm gaurds all lifted up on 27" GBC SPARTICUS tires on ITP system 6 rims, uni air filter and fender flares on the way
Old 05-22-2011, 01:36 PM
cwlongshot's Avatar
Question
I don't know anyone with one so I cannot check.. but I thought all 850's had a brake at each wheel?
Old 05-22-2011, 01:39 PM
skizmo's Avatar
Member #13773
really eh..that's actually quite discouraging tho....because there specs make it sound like there are 4 disk brakes....thanks so much cw...i almost had a heart attack!..lol..I had no idea about the locking rear axles.;..it all makes sense now......my buddy has a 2011 850..when he gets home im gonna get him to look and see if he has 3 or 4......when you spend this kinda coin..and your new to mechanics and the inner workings of a atv it sure does get stressful not knowing...I can continue cleaning in peace.
thanks again guys
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
Old 05-22-2011, 01:53 PM
Member #11395
i have a 2010 850 only 3 brakes the only xp model 550 or 850 that will have 4 are the ones built in 2009 after 2009 they decided that one was enough apparently in my honest opinion i think its plenty i usually my engine braking to my advantage and let of the throttle coast into the corner then throttle it again and when i do use my brakes i use the hand brakes just what im used to i guess. the way i look at it is if you hit your back brakes they lock up pretty much it seems like because of your rear diff. i think it is very possible to add a 4th rotor to your xp if you want it but id try looking for stronger brake pads maybe? there reletivly cheap there just a pain in the ass to put back in.
Old 05-22-2011, 01:57 PM
NaplesMudder's Avatar
Member #15215
Skizmo Your model should have EBS The greatest thing about EBS is it brakes for you! Just by letting off the throttle. I use my brakes only to let riders behind me know im slowing. Usually just "taps" to light my brakelight. I was concerned when i realized my machine only had brakes on 3 wheels. Now i never even use em. Parking brake when im parked, taps to let the riders behind know and thats about it.
2005 Polaris Sportsman 700 Twin - Green -
27" Bear Claws StI HD alloy rims
Uni air filter
Kolpin rear Storage w/cooler
Front Brushguard
Rear Brushguard
3 Headlight Mod
2up Footpegs
Pure Polaris Handguards
Stage 1 Dynojet kit
1998 Kawasaki Bayou 220 Yard mule
Old 05-22-2011, 02:03 PM
skizmo's Avatar
Member #13773
i will say yesterday when i was pulling in the driveway off a gravel road..i wanted to see what would happen if i just stepped on the foot brake...and the rear tires did lock up and i just skidded to a stop..bout 20-30 feet....it felt like on the old peddle bikes when i was a kid when you just cranked back on your pedals and you would do those wicked skids....lol
Get Some!
Custom 2-Up Seat
27' Swamp Lights
Garmin GPSmap 62
atv 4 wheel disk brakes
back wheels locked up on a quad
disc brake conversion kits for polaris
does the 2007 polaris sportsman have two rear brakes
how many rotors are on a polaris 700
how many rotors are the rear of a 2007 polaris 700 sprortsman
how to change front brakes on polaris predator 90
how to replace brake shoes on a polaris sportsman 90
my polaris 700 locks up the rear whee
polaris 3 wheel braking
polaris 700 twin 2007 rear brake line
polaris 90 disc brake
polaris 90 disc brake conversion
polaris atv with four disks brakes
polaris front brake brake locking up
polaris sportsman brake freeze up
rear brakes on a polaris four wheeler
what atv's have four wheel disk brakes?
what rotors to buy for 2007 polaris sportsman
why polaris atv uses only 3 discs
Its possible conver in 4 disk a 850 XP 2010 ? ZEUS ATV Brakes & Suspension 13 10-07-2010 06:08 AM
rear disk spinning benjam ATV Brakes & Suspension 6 08-20-2010 03:02 AM
Only 3 disk brakes ?? gb568 ATV New Members 3 08-16-2010 05:42 PM
predator 90 disk brake upgrade polecat88 ATV Performance Modifications 3 05-15-2010 07:15 PM
Brake Rotors country hermit ATV Brakes & Suspension 3 12-18-2009 04:13 PM
