Old 05-22-2011, 02:41 PM
rangerboy101's Avatar
Member #14812
Rear caliper problems
I was thinking my rear caliper was seized on my 99' Sportsman 500. I removed the caliper from the bracket, tied it up with some wire, and moved the four wheeler a couple feet. Now I never removed any lines or anything, just removed the caliper. I went to reinstall the caliper and I had to pry open the brake some to get it to slide over the rotor. I got the caliper back over the rotor and got everything hooked back up. Now when I press the foot brake it doesn't close the caliper at all but when I squeeze the hand brake it closes just fine BUT the caliper won't open back up. Sorry if any of that is confusing. I'm thinking the caliper is seized and I've got a problem with the foot brake. There's no air in the lines. Any ideas as to what's wrong?
1999 Sportsman 500
Stock
Old 05-22-2011, 02:55 PM
cwlongshot's Avatar
You likely blew the seals in the caliper... You should never depress the brake without the disc between the pads...
The piston inside the caliper is only designed to move so far. making it more farther can push it out of its bore, usually tearing the seals as it goes.
Sorry man, I am sure its not what you wanted to hear.
Old 05-22-2011, 04:27 PM
Member #14812
So what's the fix? Rebuild the caliper? Or is it not rebuild able?
1999 Sportsman 500
Stock
Old 08-12-2011, 05:31 PM
drogers's Avatar
Member #17639
actually i just had a similiar problem. you need to adjust the nut on the lever on the caliper that gets pulled down when the brake pedal is applied, or if you get new pads and press the piston in with a c clamp or something and put it back together the lever on the mechanical braking of the rear works fine
05 polaris sportsman rear brake seized
2007 polaris sportsman 500 rear brake problems
99polaris trailblazer brake issue
atv calipers
brakes seized up on china four wheeler
chinese atv rear brake problem
how do you repair the caliper on a polaris sportsman 500
how to rebuild polaris brake caliper
how to rebuild rear brake caliper on 08 sportsman?
how to replace polaris caliper seals
leaking polaris caliber
polaris atv brake seals
polaris atv hand brake problems
polaris sportsman 500 rear brake siezed
polaris trailblazer rear caliper
rear caliper for polars
rear caliper wont close
replace rear brake seal on 2007 polaris 500
seals for polaris disc brake calipers
squeeze open atv brake calipers
Need Rear Caliper pharlo1 Polaris Magnum 3 04-30-2011 07:56 AM
rear brake caliper motodad224 Polaris Trail Blazer 6 04-13-2011 08:00 AM
SP 500 Rear Brake Caliper Polaris_Junkie ATV Brakes & Suspension 2 03-25-2011 03:18 PM
HELP!! Rear Caliper stuff4mason Polaris Trail Blazer 1 12-10-2010 06:37 PM
Rear Caliper shootemup56 ATV Parts for Sale 1 03-22-2010 12:46 PM
