Old 05-26-2011, 02:37 AM
trex's Avatar
Member #15402
Xplorer 300 heavy duty rear spring?
Hi.
I cannot seem to find anyone selling a heavy duty rear spring for my Xplorer 300 97'. The oem spring is in my opinion too soft, especially when I am carrying tools and stuff in the rear. It also gives less clearance to the trailer coupling.
Does anyone know where to get a hold of such a spring?
Thanks,
Tommy.
Old 05-26-2011, 06:32 AM
Old 05-26-2011, 08:00 AM
tt425's Avatar
Member #3687
If it has one shock under the seat with a spring on it, it can be adjusted to make it stiffer.
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again)
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
Old 05-26-2011, 11:56 AM
trex's Avatar
Member #15402
Ah, nice. Didn't know that. Have you got a quick recipe for how to adjust it?=
Thanks!
Tommy,
Old 05-26-2011, 03:11 PM
tt425's Avatar
Member #3687
I think you just rotate the silver part on the bottom(it has different settings on it)
1995 425 4x4 Magnum
Old 05-29-2011, 12:52 PM
ya spray adjuster with wd 40, jack machine up and put jack stands under frame so swingarm has all the weigt off of it, can turn adjuster with large pair of channel -locks
Tags
heavy duty rear spring, rear spring, xplorer 300
1995 polaris xplorer rear spring soft
1996 polaris xplorer 300 rear shock
1999 polaris atv front shock duties
1999 polaris xplorer 400 rear spring
98 polaris xplorer 300 4x4 rear shock
how do you adjust the rear spring on a 1994 polais 300 atv?
how to adjust back brakes on polaris xplorer 300
how to adjust rear brakes on a 1995 polaris 300 atv
how to adjust rear brakes on polaris 300 xploreer
how to adjust the rear brakes on polaris 300 xplorer
polaris 300 rear shock
polaris atv rear springs upgrades
polaris magnum 425 heavy duty rear spring
polaris xplorer 300 for sale
polaris xplorer 400 stiffer rear shock
polaris xplorer heavy duty springs
polaris xplorer rear spring weak
rear shock for 1996 polaris xpoler
shocks for 1996 polaris xplorer 300
xplorer 400 rear shock
Super ATV Heavy Duty Axles Super ATV Super ATV 9 04-21-2011 01:44 AM
04 Sportsman Heavy Duty Springs??? 04sportsman ATV Brakes & Suspension 3 03-28-2011 02:33 PM
rear spring adjustment cam cityboy21 Polaris Sportsman 0 02-03-2011 09:57 AM
05 sportsman 800 Rear spring ???? bmac6494 ATV Brakes & Suspension 2 01-27-2011 05:49 AM
800 twin rear spring change out bighon ATV Brakes & Suspension 5 09-12-2010 05:01 PM
