Old 05-28-2011, 07:39 AM
trailboss93's Avatar
Member #15298
breaks rubbing
I just put new pads on my trailboss and the breaks rub the rotor is there a way to adjust it?
Old 05-28-2011, 09:10 PM
UpNorth's Avatar
Member #13725
There is no adjustment except maybe than rear brake peddle height. I take it brakes were working before pad replacement? If so I would check the level of brake fluid in reservoir if it is too full, this cause pads will rub on rotor and the fluid brake to heat up and expand and with no place for fluid to go it will apply pressure up to the point it may lock up brakes. If level is OK I would check to see if the your caliper(s) are free on their mounting pins. If they are dirty and corroded that can cause pads to drag.
Old 05-29-2011, 02:52 AM
cwlongshot's Avatar
Morning,
Its been a while since I did mine, but on my wife's 2000TB you can (have to) adjust the calipers or they will rub as your saying.. I don't have the manual handy...
Maybe your years are different.
atv brake rubbing
atv brakes rub
atv rear pads rub in reverse
back brakes are rubbing quad
brake pads rubbing atv
brakes rub in reverse after rear brake change on atv
brakes rubbing on atv
brakes rubbing on polaris sportsman
breaks rub after new breaks
calipers rub wheel after installing new pads
do brake pads rub on atv
how do you adjust brakes from rubbing on atv
my brakes are rubbing on atv
new brake pads rub on atv in reverse
polaris predator 500 changed rear brakes now they are rubbing
predator 500 front brake rubing
predator brake pads rub
what would cause polaris atv brakes to lock up
why does predator 500 rear brakes lock up
why is my brakes rubbing on my atv
breaks question notdaddys ATV Brakes & Suspension 6 05-05-2011 07:43 AM
4x4 breaks on test drive... tore apart, magnet? LDsportrider Polaris Sportsman 2 03-30-2011 06:39 PM
07 Predator 500 breaks up mid range tjhndnh ATV Repair and Maintenance 2 02-21-2011 11:35 AM
Headlight Pod Rubbing ERV Polaris XP 4 11-27-2010 06:25 PM
Rod Ends Rubbing Tires rookie racer Polaris Sportsman 16 04-01-2010 05:07 PM
