Old 05-31-2011, 09:51 AM
cowboy643's Avatar
Member #15579
Rear tires lean
I bought a 2005 Polaris sportsman 700. The rear tires lean in at the top. I bought this Atv used. I replaced all the a arm bushings and wheel bearings. It still has the same lean. Just wondering if the a arms could have been changed out and they are wrong or the hubs could be wrong. I know the guy did work on the Atv just not sure if he changed anything on the rear. Can't seem to locate the guy I bought it from now to ask him. Thanks for any help.
Old 05-31-2011, 11:04 AM
Johnnnyboy's Avatar
Member #15121
sounds like your rear springs are shot
Old 05-31-2011, 11:18 AM
cowboy643's Avatar
Member #15579
I have replaced the rear shocks also.
Old 05-31-2011, 11:23 AM
I agree though it sounds like the shocks are sacked out. New struts wouldn't help if the springs are fatigued.
Do you know if they rode two up on this machine, carry a sprayer or other heavy object, tow a heavy trailer recently?
Old 05-31-2011, 11:31 AM
cowboy643's Avatar
Member #15579
I don't think so. To me it looks like either the upper a arm is too short or the bottom a arm is too long. Im not sure I have never seen this before. I have always rode yamaha.
Old 05-31-2011, 11:32 AM
cowboy643's Avatar
Member #15579
I don't know if there is a difference in length for different years for a arms.
Old 05-31-2011, 11:51 AM
I think somewhere on the a-arm, the part number should be stamped on it.
I don't think there is a size difference between the full size sportsmans, unless the previous owner did a hack job.
I have seen in addition to the rear being sacked by chemical sprayers and such, I have seen the front ends on sportsmans sacked out from having a plow on it for a length of time. It would make the front tires tilt in, a lot even once the plow was off
Old 06-01-2011, 06:11 AM
NaplesMudder's Avatar
Member #15215
My 2005 has the same exact "toe-in" in the rear tires as you have described. Ive had the rear end gone through and can say without a doubt its just the way the machine is.. I will add though..i only see the toe-in when i ride two up. Does your machine look that way with noone sitting on it? I had a guy following me the other night stop me and tell me my wheel was falling of!! lol I guess hes never seen IRS when the wheels are riding on uneven ground! Keep in mind with IRS the wheels will seperate to give them more traction either on uneven ground or when you have extra weight towards the rear of the machine. If you have a toe-in with no weight on the machine i would say you have a problem. If your wheels look normal without two riders or excessive weight..thats normal.
2005 Polaris Sportsman 700 Twin - Green -
27" Bear Claws StI HD alloy rims
Uni air filter
Kolpin rear Storage w/cooler
Front Brushguard
Rear Brushguard
3 Headlight Mod
2up Footpegs
Pure Polaris Handguards
Stage 1 Dynojet kit
1998 Kawasaki Bayou 220 Yard mule
Old 06-01-2011, 06:37 AM
cowboy643's Avatar
Member #15579
After talking to several Atv shops I was told because of my 3" lift and 32" gorilla silverbacks tires. The rear tires are going to lean in some at the top. Does anyone know if there is a company that makes a longer top a arm to fix this.
Old 06-01-2011, 09:41 AM
Member #15215
Ahh the bigger tires answers the question. After my post i decided to look at mine again and realized my lower a arm bushings are sloppy. Hence my lean in when theres substantial weight on the bike. I could go with a kit and replace the whole deal but im gonna change the lowers as the uppers are tight. Part# 5438902 x 8 Part#5632291 x 4 should fix my lean. = D
Cowboy im sure with a good search engine and the right keywords you can find a shop that does custom aarms. Lift kits will obviously change the angle to your arms and i would think someone out there has custom arms to fit your needs. good luck!
Uni air filter
Front Brushguard
Rear Brushguard
3 Headlight Mod
2up Footpegs
Stage 1 Dynojet kit
atv tires leaning
front tires leaning in on 2005 polaris
front tires on polaris 500 sportsmen tilt in at top
my rear wheels on polaris sportsman 500 lean in at the top
polaris 500 sportsman tires lean in
polaris atv rear wheel inward lean when loaded/how to fix problem
polaris rear tires leaning in at top
polaris rear tires tilted in
polaris sportsman 700, back tires lean in
polaris sportsman back tires lean
polaris sportsman front tires lean
rear tires lean atv
rear tires lean in in on polaris sportsman 400
tilted rear wheel polaris sportsman
tire sitting out on polaris sportsman
top of tire leaning in
why do my rear tires lean in
why do my tires lean in
why does a polaris front tires lean in
why does my tires lean out
10 vs 12" rear tires?? kool_500HO ATV Wheels & Tires 1 02-20-2011 06:18 PM
how do i know if im too lean ? p4pumpman ATV Repair and Maintenance 5 01-09-2011 01:01 PM
97 explorer 300 running lean thelloyds ATV New Members 1 10-29-2010 04:23 PM
2003 trail boss running lean cassiusclay ATV Repair and Maintenance 3 08-10-2010 06:33 AM
Front tire lean? Fatguy55 ATV General Discussion 4 05-11-2010 07:34 AM
