2000 Magnum 325 Brake Problems
Ever since I bought this ATV the piston that is actuated by the foot lever was stuck inside the housing – so I never used the foot brake – even though the rear cylinder was full of fluid.
The handlebar lever always worked great - no issues. This past weekend I was on a long ride and the machine started slowing down – turns out the rear brake was stuck on – all of a sudden.
I pulled to the side and waiting 15 minutes and it release – maybe too hot – not sure. At this point I lost all brakes whatsoever.
The handlebar master cylinder is full of fluid, so is the rear – no visable leaks anywhere – but no pressure.
Obviously, I am going to start with the rear that was sticking – but any suggestions from the forum would be appreciated.
John
2000 Magnum 325 4x4
2000 Scrambler 400 2x4
