Old 05-31-2011, 12:00 PM
mcutlass1969's Avatar
Member #15581
Replacing rear shock.
Gang
Totally new to this site but i have found through other forums that there is alot of great help out there for guys that want to at least try.
I need to replace the rear shock on my 2008 pheonix. the back of the quad bounce freely up and down easy with no resistance.
Now it appears the change out would be east. Bolts at each end, but i have concerns around the spring the shock runs up the center through. It it like on cars where there is tnesion on the spring. If so i am lookking at the tricks of the trade on how to handle the spring. OR is it just on thier to catch the bounce of the machine and there isn't alot of tension on it?
thanks
Mike
Old 05-31-2011, 12:11 PM
There is tension, but being a smaller machine, it shouldn't be too bad. Although, too much to compress by hand. I spring compressor would be best to use.
You could also probably do it with a vice grip, some tie downs, and a large metal rod. I would suggest getting an extra pair of hands to help you. ( have any buddies who owe you one?)
Just always remember a compressed spring is like a loaded gun. It can do some serious damage to you. Especially if you are not using something design for this like a spring compressor.
Old 05-31-2011, 12:31 PM
Member #15581
that is what i was thinking but never have worked on this part before I am glad i asked. I know in working on cars coil springs are very dangerious.
Thanks again
Mike
Old 05-31-2011, 01:13 PM
change out rear shock on atv
changing a polaris rear shock
changing shock on atv
diy install rear shock polaris atv
how can i remove polaris shock springs with a vice
how replace a shock on an atv
how to change a rear shock on 2000 polaris 700
how to change atv rear shocks
how to change front shock on polaris scrambler
how to change rear shock on atv
how to change rear shock on polaris scrambler
how to change rear shock on quad
how to change shocks in polaris atv
how to replace atv rear shock
polaris atv rear shock removal
polaris scrambler replaceing rear shock
removing polaris atv rear shock
removing shock on polaris scrambler
replacie rear atv shock
scrambler rear shock bolts
will a scrambler 500 rear shock fit on a 500 predator rear? hunter51190@yahoo.com ATV Brakes & Suspension 1 10-18-2010 04:18 PM
rear shock swifty scrambler Polaris Scrambler 4 02-22-2010 01:36 PM
700 rear shock jonslink ATV General Discussion 6 02-16-2010 09:02 AM
Rear Shock Question justincsandbar Polaris Scrambler 2 01-10-2010 10:09 AM
96 rear shock djtates125 ATV Brakes & Suspension 3 01-08-2010 08:10 AM
