06-06-2011, 09:15 AM
Member #15743
Sportsman 500 Brake questions
Recently purchased a 05 Sportsman 500 HO. Have done brakes on cars but ATVs are new to me. Pulled the wheels to check the brakes. All pads look like they have about 1/4 left on the pads. What is the minimum on ATV brake pads. Also, can hand turn the rotor but it is pretty tight. Is this the way the calipers should be?
A newbie says thanks!
06-06-2011, 11:04 AM
Member #858
Well dude...if their that low then replace them....rotors are going to be tight remeber your turning axles too...normal for the calibers...unless your having a pulling problem when you brake....Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
06-06-2011, 02:06 PM
Member #15743
Thanks Muddie
Wasnt sure about the pad thickness since it is such a light vehicle.
06-06-2011, 05:33 PM
Member #3805
Buy a new set of pads then bleed your system, make sure that the rotors are still usable.
06-07-2011, 02:56 AM
Member #5074
On most models the service limit is 0.150" including the steel backing plate. New they are 0.275".
06-16-2011, 04:41 PM
Member #994
Yeah a qtr inch of pad is still pretty decent these pads typically are about .30 -.35 of a inch. Keep an eye on them as they can wear quickly in mud and water. If you need pads check out our site ATV and Motorcycle - brakes or brake pads - Race Driven
2009 polaris sportsman 500 brake pads, brake change polaris sportsman, brakes issues on polaris sportsman 500, fixing brakes on polaris sportsman 500, hand brake lever on 03 polaris 500, hand brake polaris sportsman, hand brake soft polaris sportsman, hand brake stuck polaris sportsman, handbrake for sportman 500, how to change brakes on a 99 polaris 500 sportsman, how to change front brakes on a polairs sportsman, how to fix handbrake on 500 sportsman, how to replace brakes on sportsman 500, pad replace on 99 sportsman, polaris sportsman 500 brake replace, polaris sportsman 500 brakes, polaris sportsman brake change\, polaris sportsman brake stuck, replacing hand brake polaris, soft hand brakes polaris sportsman
