Old 06-20-2011, 03:14 PM
crammley's Avatar
Member #16165
foot brake piston 04 400 sportsman
just replaced the back brake pads on my 04 sportsman. bleed some fluid out and it smells. should i empty all brake fluid? my foot brake needs a new piston from what i can tell. how hard is it to change? can i just use my hand brake for now to brake? and can I bleed the brakes with just the hand lever? i have new pads to go on front as well. then i will bleed the system. is there bleed screws on the front brakes as well as the back? do i need to loosen both bleed screws on the back? any help would be great.
Old 06-20-2011, 04:53 PM
Old 06-26-2011, 06:12 PM
elmerkit's Avatar
Member #3805
Hello and welcome to the forum.
Old 06-27-2011, 02:57 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
Brake fluid smells so it is probably OK. By piston, do you mean the stepped piston in the rear caliper or the foot brake master cylinder attached to the frame near the foot brake pedal? Piston and seals for the rear caliper is 2201869 and master cylinder is 1910301. Both are rather expensive in Canada.
Both hand brake and foot brake act on the rear caliper but they are independent, why you have two bleed screws. Yes there are bleed screws on the front calipers. Start bleeding the hand brake at the rear caliper first then do the fronts. Once that's done check the foot brake. I just fixed mine and the foot brake gave me fits. The hose going to the master cylinder comes from a small reservoir under the seat and it air-locked on me. Disconnect the hose at the cylinder and when fluid comes out re-attach it. Then bleed. Your foot brake master cylinder might be OK. You can use the quad with just the hand brake. I rarely use foot brake. It's there as a backup.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
04 polaris sportsman 400 bleeding the front brakes
04 polaris sportsman 400 rear brakes not working
2008 sportsman stuck rear master cylinder piston
blled bbrakes 2001 polaris sportsman
brake bleeding polaris sportsman 400
brake fluid for a polaris atv
how do fix foot brake on polaris atv
how to bleed brakes on polaris 400 rear foot pedal
how to bleed polaris sportsman atv brakes
how to bleed polaris sportsman foot brake
how to bleed the foot brakes on a polaris sportsman atv
how to get a jammed piston out of a cylinder on an atv
polaris brake piston whichbway
polaris foot brake
polaris foot brake how to bleed
polaris sportsman 800 brake piston
polaris sportsman brake plunger
polaris sportsman foot brake bleeder screw
repairing polaris bleeder screw
www polaris sportsman 400 foot brake linkage
foot brake problems DAHOOK ATV Repair and Maintenance 7 02-27-2012 07:07 PM
auxiliary foot brake problems ericmichael54 Polaris Sportsman 4 03-21-2011 06:23 PM
foot brake question Doty ATV Brakes & Suspension 5 01-25-2011 05:54 PM
installing foot brake Boostedawd91 ATV Brakes & Suspension 3 12-25-2009 09:09 PM
foot brake line jhollen ATV Brakes & Suspension 5 12-04-2009 07:09 PM
