Old 06-28-2011, 10:10 PM
sportsman2x's Avatar
Member #15018
Front spring questions
I have 2006 500efi X2, when i'm looking at the front it seems the wheels are leaning in at the top and out at the bottom. Is this a spring problem? if so does anyone make a stiffer aftermarket spring?
Old 06-29-2011, 01:22 AM
cwlongshot's Avatar
Mornin Tenn,
I would say yes your springs are beginning to sag... Also YES you can get HD replacements!! Polaris, Hi-lifter and EPI all make them. I choose EPI but Polaris are a bit cheaper. its one of the best things I have done on my 700!! EASY to do as well! Check out one of our sponsors and get yourself a set!!
Old 07-01-2011, 11:13 PM
Razorback's Avatar
Member #4649
It's normal. Nothing to worry about. If you want to fix it, as mentioned above, there are hd spring options. Replacing them can be done in as little as 30 or 45 minutes if you're handy with a wrench. The polaris ones are $49.95 for the set. You can order them online, but if you get them at the stealer, you can probably avoid the shipping cost. If they do want to charge you shipping, just ask them to add the springs to their next stock order. You may have to wait a while to get them, but you can avoid the shipping charge.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
Old 07-04-2011, 05:24 AM
Member #15018
Will this give any additional lift to the front from the stock height?
Old 07-04-2011, 06:16 AM
Razorback's Avatar
Member #4649
Some. It depends on how much sag there is in your front end. Most people seem to get around 1" of lift or so, My front springs were so bad that it gave me almost 2.5".
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
Old 07-04-2011, 06:00 PM
elmerkit's Avatar
Member #3805
I would suggest to check your shock and spring, if you want to retain the stick height change the spring and stiffer shocks.
my wheels are leaning in on my polaris 500
polaris 500 big boss front spring lift
polaris atv front lean
polaris front spring
polaris front tires leaning in
troubleshoot polaris 500 big boss front suspension
Front Hub rebuild questions 7.62Addict ATV Repair and Maintenance 16 09-28-2011 03:56 PM
Front Spring Question duffer ATV General Discussion 0 02-02-2011 09:34 PM
homemade front spring spacer bakada ATV Brakes & Suspension 13 07-25-2010 09:15 PM
Aftermarket spring ring front axle '07 Sportsman 500 dutch Polaris Sportsman 2 07-11-2010 03:41 PM
2010 550 XP Broken Front Spring !! Sage crusher Polaris XP 3 07-04-2010 10:52 AM
