06-30-2011, 09:47 AM
Member #13889
rear brake inop on 2005 trail boss 330
Hello from Colorado,
I'm helping a neighbor with his trail boss 330, the rear brake pedal has no pressure. i bleed the rear brake caliper for a while but still no luck. is there a certain way to bleed the rear brakes or a special trick?? any idea please let me know!
Thanks,
07-01-2011, 01:36 AM
Member #5074
Had the same problem with mine. Worked on it for hours before I figured out what was wrong. Had an airlock between reservoir and master cylinder. Fluid wouldn't go down the tube from the reservoir. Took one of those small bamboo skewers you use to make kebabs and shoved it down the hole in the reservoir. Moved it up and down a few times and eventually I saw air bubbles coming out of the hole. A straightened coat hanger would probably also work. Other way you could try is to detach the rubber hose at the master cylinder until you see fluid coming out, then reattach it. Once you get fluid into the master cylinder you're OK.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
07-01-2011, 05:06 AM
Member #13889
Thanks for the advise, im going to try it tonight and hope to have the same luck that you did!
07-01-2011, 05:16 AM
Member #5074
Just a thought, you could try squeezing the rubber tube with the bleeder open. That might suck fluid into the tube from the reservoir. No such problem with the hand brake because master cylinder and reservoir are in same unit and you can't get an airlock between the two.
Rear drop rack
2000lb winch
No mods
05 polaris trail boss 330 not running, 2005 polaris 330 no rear brakes, 2005 polaris atv trail boss, 2005 polaris trail boss 330, 2005 polaris trail boss 330 rear brake caliper, 2005 trail boss forum, 2005 trail boss rear brakes not working, bleed brakes on polaris 330, fix polaris rear brakes, how to bleed rear brakes on 330 polaris atv, how to fix polairs back breaks, polaris 2005 hand brake good but no rear brakes, polaris trail boss 330 rear brake caliper, polaris trail boss 330 rear brake cylinder prices, polaris trail boss 330 rear master cylinder, rear brake 2011 polaris 330, rear brakes dont work on 2005 polaris trail boss, rear brakes on trail boss 330 not working, rear master cylinder polaris 330 trail boss, trail boss 330 brakes
