07-07-2011, 11:33 PM
Member #7771
Brake Bleeding Wrench Size
What size wrench do I need to bleed the brakes? I did a search and didn't come up with anything and I don't have a wrench now that fits. Thanks.
2005 Sportsman 800 EFI
07-08-2011, 02:41 AM
Mine are 1/4" on my '07 700
07-08-2011, 04:25 AM
Member #5074
1/4 inch on mine
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
07-08-2011, 04:41 AM
Member #1958
Yep...1/4"
07-08-2011, 05:15 AM
One thing I will add is avoid a regular wrench for these.. Use a 6PT socket or a flare nut wrench. 1/4" isn't too common for a flair nut wrench so I just use a 6pt socket or 6PT box end wrench. The fluid easily spills out between the crevasses in the socket.
Using a reg wrench or 12PT wrench/socket could result in a rounded out bleeder. NOT FUN.
07-08-2011, 07:54 AM
Member #7771
Thanks for the input.
07-08-2011, 12:57 PM
Member #7771
Picked up the flare nut wrench. Not cheap, but worth it.
07-09-2011, 08:11 AM
Member #7771
OK that flare nut wrench didn't work out so well. The one I picked up was so fat/wide that I couldn't use it while having the nipple covered with a tube. So I ended up using a regular 1/4 wrench instead.
atv brake bleeder, bleeding a brake line wrench size, bleeding brakes what size wrench, bleeding wrench, brake bleeder wrench size, brake bleeder wrenches size, brake bleeding wrench, how do you bleed brakes on atv, how to bleed brakes on polaris xpedition 325, polaris atv brake bleeder, polaris sportsman 700 bleed brakes, polaris sportsman 700 brake bleed, size of bleed brakes, what size is a brake bleeder wrench, what size wrench do i need for brake bleeder, what size wrench do i need to bleed brakes?, what size wrench do i need to bleed my brakes, what size wrench is used for bleeding brakes, what size wrench to bleed brakes, wrench to bleed brakes
