Old 07-09-2011, 06:19 PM
michaelbell85's Avatar
Member #5587
polaris scrambler lift kit cant find
went riding today and bottomed out my scrambler numerous times. Anyone know of a lift kit for a polaris scrambler.
Old 07-21-2011, 08:52 PM
scottdeet's Avatar
Member #7044
All I know of is to put taller tires on with regards to the swing arm & straight axle in the rear. If it's a 4x4 I'm almost certain you
should go the same step up for the front & rear. Meaning if you go with a
2" taller tire in the rear you go with 2" taller in the front also even if they're 2 different sizes already.
This is to keep the same gear ratio for the 4x4 working properly.
Good luck with that though as you may need to change rims.
If it's just rear wheel drive, then taller tires on the rear will raise the axle
up more for more clearance with no worry in regards to the front.
Of course taller tires may change the power a bit.
Take care,
Scott Deeter
Old 07-29-2011, 04:29 PM
poop's Avatar
Member #17131
Scott,
Why does having the same size tire matter with the 4x4? I am a noob when it comes to 4 wheelers so explain this to me, as I'm pretty sure the trailboss 4x4 I just bought has 2 different sized tires. Will damage occur if I don't have the same sized tires?
2003 Sportsman 400 4x4 - Superwinch, Tube front and rear bumpers, Factory chrome rims and tires off Sportsman 700.
poop in the house
Old 07-30-2011, 09:58 AM
scottdeet's Avatar
Member #7044
My thinking is if it came stock with different size tires front & back, then
the 4x4 is set up for these sizes to work properly. If you change the rears
to the same as the front, then the ratio will be off for the 4x4 gearing
(that's how I see it). If you go bigger in diameter, just go the same for
the front & rear, meaning 2" bigger in the back, then 2" bigger in the front.
This is my third try replying to this post and it keeps getting messed up
with the preview and losing it.
Take care,
Scott Deeter
1998 scrambler 400 rear axle
2006 polaris scrambler lift kit
fox 1.5 atv series
how to lift a polaris scrambler
lift for 1998 polaris scrambler
lift kit for polaris scambler
lift kit for polaris scrambler
lift kit for scambler atv
lift kits for a polaris scrambler
lift kits polaris scrambler
lifted polaris scrambler
polaris front scrambler 500 suspension upgrade
polaris scrambler 400 lift kit
polaris scrambler 500 4x4 lift kit
polaris scrambler 500 lift kit
polaris scrambler lifted
Question about a 2" lift for Polaris Sportsman NickS ATV Performance Modifications 39 01-02-2012 12:11 PM
2002 Polaris 700 Lift Kit Needed Mag Polaris Sportsman 3 06-08-2011 04:02 PM
Brand New High Lifter 2" Lift kit for 05-06 polaris sportsman 600,700,800 850 XP RIDER ATV Parts for Sale 0 05-20-2011 01:09 PM
where can i find scrambler 400 stroker crank? gettherefast Polaris Scrambler 5 04-15-2010 08:45 PM
Polaris Sportsman 500 Lift Kit ipaman ATV Parts for Sale 0 03-29-2010 08:42 AM
