Old 07-18-2011, 05:05 AM
aflumb's Avatar
Member #15000
Rear Axle removal
So for the last week and a half i have been in the process of replacing all the bushing on the rear suspension on my 2002 Sportsman 500. well i also needed to replace the left (sitting on atv) rear inner boot. its been ripped for a while but not much riding. now to the fustrating part. i have been trying for 2+ days to get the axle out of the trans. im really hoping one of you guys can give me another idea to get it out. i am a mechanic and know how to get these type of axle out. it just seems to be locked in there. i have tried prying with 2 pry bars, lubing it, and snatching the h3ll out of it. im just not getting any where. i would really be thankful for any other ideas.
Old 07-18-2011, 05:25 AM
robkelley13's Avatar
Member #3191
I just replaced mine and I ended up having to put it completely up on jack stands, have a friend put it in low gear and keep lightly bump the throttle to move the axel, while I was using a flat prior bar and a hammer tapping it in and trying to hold it wedged in between the rear end and the joint housing. Eventually it loosened up and poped right off.
Old 07-18-2011, 05:38 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
If it's like my 2001 500HO there's a circular groove near the inboard end of the splines. There's a locking ring which sits in the groove and there's a gap in the spring locking ring so that it can compress. My manual says the following; "Pull sharply outward to remove shaft from transmission. Install a new lock ring upon assembly." The ring is on the right of the parts diagram.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
Old 07-18-2011, 06:45 PM
Member #1958
I haven't tried it but there's a guy with a youtube video on the net entitled something like "Redneck axle removal" that looks like it'd work. He laid the machine up on it's side and removed the outer part of the axle. He then wrapped a chain around the short shaft into the differential and hoisted the bike a couple inches off the garage floor with a ratchet tie down to the rafters. He then whacked on the shaft after having soaked it with PB Blaster. It popped right out. It's a little extreme but would work for axles that have rusted in place.
Good Luck!
Old 07-19-2011, 03:23 AM
aflumb's Avatar
Member #15000
thanks for the info everyone. so after soaking it all night and the next day. i got home yesterday after 3 good pulls it was out. and the problem was rust. i dont think this axle has ever been out.
so i got everything apart, and replaced. now it seems it doest want to go back in. but ill get it soon. still got to wait on the rest of my bushings for the other side any way!!
Old 07-19-2011, 04:26 AM
Member #1958
Way to go aflumb...I recently picked up an 02 that had bad boots and rather than go through all that hassle I just took the axles apart leaving the short shaft in the differential and rebuilt them on the bike. I soaked them good and will deal with complete removal if/when it becomes necessary. Had'em done and back on wheels in about 2 hours.
I was always told there's more than one way to skin a cat!
Old 07-19-2011, 04:32 AM
Member #3191
If I remember right put the gap on the snap ring up, which will allow it to stay in place better and it should slide right in. If that doesn't work put the gap of the ring down. Can't remeber which way it was but I do remember if it was on the side it wouldn't go in at all.
Old 07-19-2011, 06:48 AM
aflumb's Avatar
Member #15000
cool thanks for the tip. that was my probem. that and i dont want to pull the new boot loose. ill give it a try tonight. then ill let you guys know what happend.
Old 07-21-2011, 07:16 PM
aflumb's Avatar
Member #15000
update:
so i got the jeft side all done and back together . no im just waiting on a couple more bushings and ill be ready to finish the right side. tom. im going to order a new starter and bendix seeing as mine has decided to quit on me. oh well.
Old 07-25-2011, 06:13 PM
aflumb's Avatar
Member #15000
finally done
so after a week of waiting on parts, i finally got my quad back together. rode it around the sub divesion. cant wait to go back to NC to ride for real!
02 polaris sportsman 500 ho left rear axle
2000 polaris sportsman 500 rear axle removal
2001 polaris ranger rear axle
2001 sportman 500 ho rear axle boot replacement
2002 polaris sportsman 700 rear axle
2002 polaris sportsman rear axle removal
2002 sportsman 500 ho rear axles
cant get retaining ring back in groove on polaris
diagrams for polaris sportsman 500 rear axle removal
how do you remove the axle bearings on a 2002 polaris ranger
how to change back axle boot on polaris ranger
how to remove a rear axle on a 2002 sportsman 500 polaris
part diagram for polaris sportsman 500 rear axle
polaris 2001 sportsman rear axle removal
polaris axle removal
polaris ranger axle install
polaris rear axle removal
poolaris rear axle boot remove
removing atv rear short shaft
Left rear axle shaft removal. Chazzo ATV Brakes & Suspension 13 04-01-2012 02:08 PM
U-joint style rear axle removal Diesel Polaris Sportsman 5 11-28-2011 09:51 AM
Rear Axle Removal Hullhorr ATV Repair and Maintenance 10 10-23-2011 04:49 PM
sportsman500 rear axle removal Texan42 Polaris Sportsman 4 10-28-2010 04:12 AM
HELP 03 Ranger Rear Axle removal Airpig95 ATV Repair and Maintenance 1 10-25-2009 05:01 PM
