Old 07-18-2011, 05:50 PM
blueridgerunner's Avatar
Member #15743
Sportsman 500 HO suspension and rear brake
Hi,
Fairly new to ATVs so dont have much experience and would appreciate your response. I bought a used 05 Sportsman 500 HO a few months ago. Now has about 150 hrs and 750 miles. Every so often if feels like the steering is very loose. Hasnt happened much but when it does it feels like there is a lot of play in the steering and the front end is moving around by itself. Kinda scary on a steep gravelly trail this week. If I stop and then start moving again it usually stops. Was reading another post about spring sag. My front wheels are both tilted in at the top quite a bit. Thought this was how the Sportsman was but maybe wrong. Could this cause the steering problem?
Also quick question about the foot brake. I know this is a backup brake but I have to stand on mine to get any braking. Is that normal?
Thanks for any help.
Old 07-18-2011, 06:34 PM
ebaysnyper's Avatar
Member #13772
Send a message via Yahoo to ebaysnyper
The back break has a resavuar under the seat make shure it has fluid in it (dot 4) and jack the front of the bike up in the center so bolth front tires are off the ground then grab the tire and give it a shake. Wile shakin it you should be able to see if anything it loose. It could just need greasing or some bushings let me know what you find ill post up a link to free pdf manual for you in a few.
Pardon my spelling
Sent from my DROID3 using Tapatalk
2007 sportsman 500 x2 efi
26" sadona ripsaws on 12" itp ss312's
3 headlight mod relay type
2500 Ib polaris winch
custom made "winch saver"
custom work light mod with lighted switch and 18 Watt lamps
custom stealth black shock covers
Front trunk locks Polaris Part #2874548 $7.50 each @ dealer
front rack rails converted to "U channel" strut for easy attachments
pure polaris HD front springs
Old 07-18-2011, 06:41 PM
ebaysnyper's Avatar
Member #13772
Buy the way great bike and nice low hours, can I ask what it cost you? I payed $4200 for my 07 500 x2 efi with 1500 miles.
Here's the manual from my collection
http://www.megaupload.com/?d=OTHPCNDA
Old 07-18-2011, 06:45 PM
Member #15743
Actually bought it about a year ago. Had just under 500 miles and just under 100 hrs. Paid $3000. Mid summer seems to be the best time to buy a used one.
Old 07-18-2011, 07:01 PM
ebaysnyper's Avatar
Member #13772
Great deal.
Old 07-18-2011, 07:46 PM
dino1's Avatar
Member #16857
Check and make sure your tie rods are in good shape. Like ebaysnyper said check for play. tie rods are the last thing you want to fail on the trails.
Old 07-19-2011, 08:14 AM
Razorback's Avatar
Member #4649
The rear brake sounds normal. When just applied by itself, without the front brakes, it doesn't give all that much stopping ability.
Things that can cause steering problems:
Tie rod ends
Wheel Bearings
Ball joints
A-arm bushings
The front end sag is normal. If you want to straighten it out, the HD springs are $50 for the set at the dealer.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
Old 07-19-2011, 10:47 AM
Member #15743
Newbie says thanks for all of the posts.
05 sportsman 500 manual pdf
2007 polaris sportsman 500 brake lock
2007 polaris sportsman 500 rear brake problems
2011 polaris 500 rear brake clicking
bad breaks on 2007 polaris sportsman
diagram rear brakes 2009 sportsman 500 ho
front wheels tilted on my atv
polaris 2006 x2 rear suspension disassembly problem
polaris 500 atv front suspension sagging
polaris 500 h o single shock in back
polaris 500 sportsman rear break bleeding
polaris sportsman 500 back brake
polaris sportsman 500 rear brakes
polaris sportsman bad foot rear brakes
polaris sportsman rear suspension
polaris sportsman suspension problem
putting rear brakes on polaris 500 ho
rear brake caliper for 2007 polaris 500 ho
tilted rear wheel polaris sportsman
why are my back wheels tilted in
03 330 Sportsman Rear Suspension Parts 92turbo2 ATV Parts for Sale 20 04-17-2012 09:41 AM
2002 sportsman 500 rear brake help crashnburn ATV Repair and Maintenance 2 03-15-2011 12:13 PM
05 Sportsman 500 HO Rear Brake Problem jhartson ATV Brakes & Suspension 6 11-23-2010 01:47 PM
WTB 04 Sportsman 400 rear brake parts ngansen ATV Parts for Sale 0 09-06-2010 08:06 AM
Sportsman 500 HO rear suspension issues skuirrelly ATV Brakes & Suspension 11 08-07-2009 07:47 PM
