Old 07-21-2011, 04:48 AM
mikmazz's Avatar
Member #16941
1997 xplorer rear brake rotor noise
I have a 97 xplorer and the rear floating rotor make a racket when driving due to if flopping around at the bottom below the caliper. I installed new brake pads and adjusted the caliper but the rotor still has play and still makes noise but not as bad. Any suggestions???
Old 08-01-2011, 03:18 PM
MUDDIE49's Avatar
Member #858
I'd ride it alittle not beatening on it...the pads might seat better as they warm up and quiet the rotor down....if not replace the rotor...Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
Old 08-01-2011, 03:53 PM
dieseldan2005's Avatar
Member #2090
I seriously was going to post something on this too! I have the same wheeler and the same problem. Mine makes a bunch of racket when riding too. I looked at it again tonight and i can't seem to find a way to fix it.
Old 08-02-2011, 05:32 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
Friend of mine has same ATV and his is quiet. Rotor can't be fixed because caliper is single piston and fixed. Rotor has to float. Is it possible your rotors aren't flat? If the pads are adjusted close enough to the rotor, the rotor shouldn't be noisy.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
Old 08-02-2011, 05:56 PM
Member #2090
I will have to look at it more. I don't think there is a way to tighten em up anymore. The pads are still good.
Old 08-02-2011, 10:52 PM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
the brake rotor or the rotor shaft is worn out,i've had to replace one or the other or both at one time or another for customers.always full floating causes wear and play on the shaft and rotor.
Old 08-03-2011, 03:10 AM
pjmartin's Avatar
Member #5074
They are tightened up using the bolt and locknut where the footbrake lever attaches to the caliper.
Rear drop rack
2000lb winch
No mods
Old 08-03-2011, 04:12 PM
Member #2090
Anyone have a part # for that rear rotor? I can find the fronts but no rears. Also does anyone else make an aftermarket one? Even don wood polaris wants $48 each for the fronts.
Old 08-04-2011, 12:32 AM
pjmartin's Avatar
Member #5074
You haven't said which explorer you have. For the 300 and 400 it's 1910177 and for the 500 it's 1910188
Rear drop rack
2000lb winch
No mods
Old 08-04-2011, 04:48 PM
Member #2090
Yes i have the 500. Thanks for the numbers. I checked and its a $92 dollar part! I can get rotors for my F250 for that price!
1996 polaris 400 xplorer change rear brakes
1996 polaris sportsman 500 rear brake
1996 polaris sportsman 500 rear shocks
1996 polaris sportsman brake noise
1996 polaris sportsman rear brake roto
1996 polaris sportsman rear brake updated rotor
1997 brake clip polaris atv
1997 polaris sportsman 500 rear brake rotor
1997 polaris xplorer rear brake caliper
96 sportsman 500 rear rotor
97 sportsman rear rotor
how to install rear brakes on 97 polaris xplorer
how to remove a rear brake rotor on a polaris sportsman
how to replace 2000 sportsman 500 brake rotors
information on the rear brakes on a 1997 polaris sportsman 500 atv
polaris 1996 sportsman 500 rear brake disk
polaris 1996 sportsman rear brake
removing rear brake rotor on 1996 npolaris sportsman 500
rotor de un polaris
what holds rear brake disc 1996 polaris sportsman
Rear Brake Noise jwmoore Polaris Sportsman 7 01-18-2012 08:03 AM
rear brake rotor rodney Polaris Sportsman 3 06-21-2011 11:31 AM
1996 sportsman rear rotor eswiger ATV Brakes & Suspension 5 10-02-2010 05:55 AM
loose rear brake rotor jeepster651 ATV Repair and Maintenance 1 08-10-2010 10:22 AM
1997 Trailboss brake noise tcabral ATV Brakes & Suspension 2 10-19-2009 04:26 AM
