Old 07-24-2011, 10:47 AM
CHUDDLESTON's Avatar
Member #8745
Question positive camber after lift?!
i installed a 2" lift kit to clear the 27" Mud Lite XTR's on my '03 Sportsman 500HO and now the front wheels have a positive camber (out just a little at the top). This makes steering a fight! any suggestions or solutions appreciated. At this point I am just about ready to take the lift back off and let the tires rub!
Old 07-24-2011, 12:27 PM
cwlongshot's Avatar
Try softening the shocks and check your toe. Camber shouldn't have a big negative in steering. Handling YES, steering not so much.
The lifts I have seen shouldn't change amber at all....
Old 07-24-2011, 01:42 PM
lost cause's Avatar
Member #9763
Who makes the lift? A 2" lift should not cause enough of a difference to cause any issues.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 07-24-2011, 03:42 PM
Member #8745
The lift is made by many different companies but all look the same. It is the one that adds a spacer on top of the front strut, which rotates the lower a arm down and thus in, causing the change in camber. No upper a arm on front but the top of the strut attaches to the same point so the geometry is changed. With weight on the bike (i.e. a rider) the front wheels are closer to vertical.
Old 07-24-2011, 03:49 PM
Member #8745
Ok, possibility the change in geometry also changed the toe...because the spindles are actually a little further from the steering stem... I may be toed out just a little and that would cause difficulty in steering. Right? I need to look at it closer.
Old 07-24-2011, 03:55 PM
cwlongshot's Avatar
Wink
Correct, suspension travels in a arch, so where it sits static is what you set it at. It most likely changed.
I had to do the same thing when I installed HD front springs. Mine was toed out 1/4". Not good... I adjusted to 1/16Th in.
Old 07-25-2011, 02:00 PM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
The maintenance manual for my 2001 500HO says the front wheels should be toed out. Put a mark at the center back of each tire and take a measurement between marks. Rotate until marks are at the front of each tire and the measurement should be 1/8-1/4 inch more.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
Old 09-04-2011, 09:00 AM
polaris5000's Avatar
Member #8548
I have a 2009 Sportsman 500HO.It has 3400 miles.Tread on both front tires is worn down to
carcass of tire body.Some wear remaining on centre lugs.Running 5 psi. Original factory tires.Rear tires are good for another 2000 miles.Right front has more wear.More negative camber evident on right front.Can the camber be adjusted ?
A friend's Arctic Cat uses upper and lower control arms with no camber. He says it is difficult to
turn on paved roads on his machine.His tires show little wear.
Thanks, Jim
Old 11-23-2011, 12:33 AM
TheJCW's Avatar
Member #18688
You used camber kits for your wheel alignment? I suggest that you just lift it back if you are having problem steering.
2007 polaris sportsman 500 camber
adjust camber after lift
adujust the camber on an artic cat
atv steering after lift
change camber on 2007 polaris 500 ho x2
do i use a positive camber kit to correct positive camber?
does lift kit cause massive positive camber in atv
fix camber after lift atv
fixing positive camber on atv with struts
how do i stop positive camber on polaris sportsman
how to adjust camber on polaris sportsman 500
how to fix front tire positive camber with lift kit
leveling kit cause positive camber
leveling kit wheel camber issues
lift kit tighted atv steering
polaris 800 front wheels are toed out
polaris camber
sportsman 800 camber problem after lift
what causes front wheel camber on an atv
why positive camber in off road vehicles
What is the best machine for off-camber log hauling? polaris_wanna_be ATV Purchasing and Price 3 07-19-2011 10:56 PM
Caster/Camber or Toe adjustments?? Lockon Polaris Sportsman 6 03-23-2010 04:36 AM
Access to positive battery terminal? eastern_hunter ATV Repair and Maintenance 2 03-06-2010 09:47 AM
Sportsman 500 4wd Camber Judas6184 Polaris Sportsman 9 01-16-2010 05:41 PM
'05 Sportsman 800 camber issue rotaxdave1 ATV General Discussion 0 01-09-2010 07:02 PM
