Old 07-29-2011, 09:52 PM
WistfulSine398's Avatar
Member #17220
425 magnum foot brake
I have a 96 magnum and it has no foot brake what do you think is wrong with it. When i step on it has no preasure. I looked only on the outside and i cant find out what is wrong with it.
Old 07-30-2011, 02:21 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
It's a mechanical linkage to the rear caliper. It's adjusted by screwing in the hexbolt on the outboard center of the caliper. Screw it in until the pads start to touch the disc and adjust from there until the pedal is 1 inch from the footrest with 50 lbs on it.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
Old 07-30-2011, 05:08 AM
Old 07-30-2011, 07:08 AM
Member #17220
Smile
Thankyou for the information
foot brake pressure switch on polaris sportsman
how to adjust brake on polaris magnum
how to put breaks on a polaris 425 magnum
install front brakes on polaris magnum 425
magnum 425 brakes
polaris 07 rear brake pressure
polaris 425 magnum brake adjustment
polaris 425 magnum brakes
polaris 425 magnum front brake picture
polaris 425 no brakes
polaris atv foot brake
polaris atv foot brake problems
polaris footbrake
polaris magnum 425 4x4 brakes.
polaris magnum 425 foot brake
polaris magnum 500 no rear brake pressure
polaris magnum no brake pressure
polaris magnum no rear brakes
polaris magnum rear brake adjustment
where are front brakes on polaris 425
foot brake problems DAHOOK ATV Repair and Maintenance 7 02-27-2012 07:07 PM
auxiliary foot brake problems ericmichael54 Polaris Sportsman 4 03-21-2011 06:23 PM
foot brake question Doty ATV Brakes & Suspension 5 01-25-2011 05:54 PM
installing foot brake Boostedawd91 ATV Brakes & Suspension 3 12-25-2009 09:09 PM
foot brake line jhollen ATV Brakes & Suspension 5 12-04-2009 07:09 PM
