Old 08-01-2011, 11:13 AM
jakes99trailboss's Avatar
Member #17012
Rear Brake Doesn't Work
On my '99 Trailboss, the rear foot brake doesn't work. The handlebar brakes work perfectly, but the foot one doesn't. Does it have a separate reservoir, or does it just need to be adjusted? Thanks
Old 08-01-2011, 11:42 AM
Is it hydraulic or cable operate brake for this model?
It sounds hydraulic, but I was thinking it was only cable for some reason.
Old 08-01-2011, 11:46 AM
Member #17012
I am not home to look at it now, but I remember seeing in the manual how to adjust it. I know the front ones are hydraulic, because they use brake fluid, but the back one I am not sure about. I really don't know a lot about brakes, how would you tell which it was?
Old 08-01-2011, 11:54 AM
If the rear is hydraulic, it will have it's own master cylinder and resivoir near by, and will have a rubber hose running to it.
If it's cable, it will basically have a cable running back to it, with an adjustment nut by the caliper.
I am on my phone, otherwise I would just pull up a microfiche and look myself.
Either way, both systems are easy. I'll keep checking back, or look tonight to see what system you have. Then we go from there.
Old 08-01-2011, 11:57 AM
Member #17012
Ok, great! I really appreciate it.
Old 08-01-2011, 01:09 PM
Member #1958
The foot brake is mechanical...you loosen the jam nut on the center bolt then tighten the bolt till you have about 1" of free play. You then retighten the jam nut while holding the center bolt to prevent it from moving.
Old 08-02-2011, 05:15 AM
Member #17012
Ok, I'll try that later and report back. Thanks
2003 polaris 600 rear brake caliper
2003 polaris 600 where is the rear brake reservoir
2003 polaris sportsman 600 broken rear brake caliper
2003 polaris sportsman 600 rear brakes dont work
atv hydraulic brake doent return
break caliper for sportsman 600
how do i fix the hydraulic brakes on my atv?
how tofix my brakes polaris 600
my polaris trail boss foot break don't work
my rear brake doesn't work
my rear brakes wont work on my atv
polaris rear brake doesnt work
polaris sportsman rear brake dont work
rear brakes dont work on my sportsman 600
rear brakes dont work on polaris sportsman 600
should the rear brake master cylinder on an atv have a rubber stopper in it
the rear brake on my polaris sportsman doesnt work
why rear brake dont work on polaris sportsman
xplorer 400 master cylinder manual
rear work lights on XP MOD mkeddie Polaris XP 12 12-04-2010 04:28 PM
Xplorer 400 4x4 doesn't work Bedrock ATV New Members 1 09-05-2010 03:42 PM
AWD doesn't work in reverse msbrockman Polaris Sportsman 1 05-01-2010 01:33 PM
Speedometer on 2003 600 doesn't work Sea-r-cy ATV Repair and Maintenance 1 01-21-2010 08:21 AM
Pull start doesn't work mnnightowl ATV Repair and Maintenance 2 01-07-2010 03:03 AM
