Old 08-02-2011, 04:58 PM
NCATVA's Avatar
Member #4655
1996 polaris Trail Blazer brakes
The machine has no brakes so I thought I would just pick pads up and put them on LOLOLOL Gusses I was wrong got the rear off and there is pad left well got then so change them any way well no matter what I try I can not get the pistion backed off enouth to get the new pad over the rotor. I have tried every thing C-clamp big channel locks and even losend up the brake line.
Does any one have any ideals?
Old 08-03-2011, 03:20 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
There's a screw/bolt at the rear caliper used to adjust the footbrake. Back off on it and this will allow the piston to retract more.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
Old 08-03-2011, 05:40 PM
NCATVA's Avatar
Member #4655
Sorry I should of meation that I have that alen screw lose I did just a couple of turn and then after I still couldn't get it to depress I removed the screw all toughter to make sure I had it fully backed off
Old 08-04-2011, 12:23 AM
pjmartin's Avatar
Member #5074
If it's not the adjustmnt screw I can only think of two possibilities. Wrong pads or a corrosion buildup on the piston. The clearance between piston and caliper is pretty tight.
Rear drop rack
2000lb winch
No mods
Old 08-04-2011, 02:54 AM
NCATVA's Avatar
Member #4655
I belive the pad are right I got them from my dealer and every thing looks the same shape and the pin holes line up and all pluse I looked them up on Pure Polaris parts and came up with the same number. Now are you thinking build up on the out side of the piston or in side where the piston slide into the caliber houseing. I'll call my dealer today and see if they offer and caliber rebuild kit for it
Old 08-04-2011, 05:00 AM
pjmartin's Avatar
Member #5074
I'm thinking buildup on the part of the piston that sits out of the caliper. You might be able to remove the piston and clean it up. Pistons and seal kits can get expensive. When you remove the piston you can look in the bore but I doubt anything could have gotten in there. If the piston is smooth after you clean it up you could reuse it. Seals are up to you but they might be fine.
Rear drop rack
2000lb winch
No mods
Old 10-14-2011, 09:15 AM
darktacos's Avatar
Member #19566
so idk if u fix it yet but do u have both brake lines on it cuz the frount brakes also opperate the rear ones so that could be stopping u from opening it all the way
1996 polaris blazer 250
1996 polaris trailblazer rear brake repair
1996 trailboss rear brake caliper
adjust rear brakes on polaris 250 trail boss
cant get any brake pressure on 96 polaris trailblazer
changing back brakes on atv polaris
how do you remove the rear brake pad pins on a 1996 polaris trail blazer?
how to adjusting rear brakes on polaris trail boss
how to change brake pads 1996 polaris trail boss
how to change rear brakes on polaris trailboss
how to fix 96 polaris trailblazer rear brakes
how to remove polaris pads
picture of 2000 atv trailblazer braks
polaris 250 rear brake caliper seal kit
polaris brakes lock up 250 trailblazer
polaris trail boss 250 1996 crankcase seals
polaris trail boss brake pad removal
polaris trail boss front caliper kit
polaris trailblazer 250 brake caliper
polaris trailblazer 250 brake kit
Polaris Trail-blazer 250 Quad masterblaster ATV Repair and Maintenance 8 01-28-2011 09:09 AM
2011 Polaris Trail Blazer 330 Prddave 2011 0 08-31-2010 01:49 PM
1996 Polaris Trail Boss 250,Need some help. Serion ATV Repair and Maintenance 3 05-01-2010 05:51 AM
2009 Polaris Trail Blazer 330 Prddave 2009 0 04-25-2010 10:57 AM
2010 Polaris Trail Blazer 330 Prddave 2010 0 03-03-2010 01:57 PM
