08-08-2011, 06:44 PM
Member #3503
2003 Sportsman 700 Spring/Lift question
Ok everyone I have a 03 Sportsman 700. I currently have EPI front and rear HD springs new not installed and a 2 in lift kit new not installed. I have been told that if I install both I'm gonna have axle problems. I've also read just a 2 in lift could cause issues but probably not. Is this true? If so which would you install? Springs or lift? I am a pretty big guy and am trying to get some more height and less squat. Any help, opinions, input would be appreciated! Thanks!
08-08-2011, 07:24 PM
Member #5629
I been using a RDC 2" lift for 2 years now with no problems. With just the lift, the axles are on bigger angles, but I'm using my stock shocks. Also, the lift will make for a stiffer ride. So I would put the lift on first, ride it and see if you like it that way. If you don't, then try the springs.
Con
08-09-2011, 11:29 AM
Member #9763
You will eventually have problems. Greater angle causes axles to break easier. It does depend a lot on the way you ride though and your setup. If you are running 26" tires and drive on hardpack you may be fine. I would go lift first. Gives more ground clearance.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
2003 polaris lift kit, 2003 polaris sportsman 700 clutch problems, 2003 polaris sportsman 700 front lift kit, 2003 polaris sportsman 700 front lift kit installation, 2003 polaris sportsman 700 lift, 2003 polaris tires with no lift, 2003 sportsman 500 lift, 2003 sportsman 700 lift, 2003 sportsman 700 lift kit, 2003 sportsmen 700 lift kit, 2in lift for a polaris sportsman 700, axle problems installing a lift on sportsman 500, easiest way to lift a 03 polaris 700, how big of tire can go on 2003 sportsman with 2'' lift, lift 2003 polaris sportsman, lift kit for 2003 polaris sportsman 700, polaris 700 sportsman 3 lift, polaris sportsman 700 clutch spring, polaris sportsman 700 lift kit, sportsman 700 lift kit
