  #21 (permalink)
Old 01-23-2012, 05:41 AM
factionfx's Avatar
Member #20681
CW, thanks for taking the time to snap pictures of the rear HD spring install. I was wanting to do the same thing, and was wondering if the spring compressors from Oreilly would work. Looks like they will! Thanks!
2012 Sportsman 500, Red.
I'm selling my ATV GURU bumpers, front and rear, BRAND NEW. PM Me an offer. For pictures see here: http://www.polarisatvforums.com/foru...500-800-a.html
  #22 (permalink)
Old 01-24-2012, 05:09 AM
Member #1958
Hey CW, I know this is an old thread but did the HD springs on the rear make the ride harsh when riding solo? I did the fronts not long after getting the 800 and love them and have been debating the rears. I run solo most all the time but run pretty aggressive and sometimes carry a lot of gear for extended stays in the boonies.
  #23 (permalink)
Old 01-24-2012, 09:03 AM
lost cause's Avatar
Member #9763
The compressors from Oreilly's is what I used for mine. worked fine.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
  #24 (permalink)
Old 01-24-2012, 09:11 AM
lost cause's Avatar
Member #9763
It will stiffen up your ride when riding solo.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
  #25 (permalink)
Old 02-01-2012, 01:48 AM
cwlongshot's Avatar
Wink
NO< I do NOT find them too stiff. I like the firmer ride. Stock it was way soft to me, so I like the stiffer springs. Plus I am a bigger guy, I mostly trail tide at moderate speeds, I dont jump or "sport" ride this machine. At times I will "speed". : I too hall allot of things in my boxes.
  #26 (permalink)
Old 02-01-2012, 03:23 AM
KICKER431's Avatar
Member #18006
Thanks so much CW. Since you never mentioned anything about getting the shocks off the machine, I assume that part was easy. Please tell me if I am wrong. I do have air tools and have currently borrowed spring compressors from a friend. I used them to change the fronts yesterday. I guess I will get ahold of Thor about some rears and not return the spring compressors immediately.
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
  #27 (permalink)
Old 04-18-2012, 04:51 PM
phil's Avatar
Member #4618
Ordered EPI HD springs for my 2010 550Xp today, from Thor. He got them out the door today as well. Tracking shows them at my door on Friday this week. Awesome job, Thor and great customer care.
My XP has only about 2600 miles on it and the suspension is sagging. I looked at the Polaris HD springs but decided that maybe the Polaris parts were not up to snuff, since my OEMs were sagging as are many on others machines. You would think they could get higher quality from the get go. I'm pretty sure I'll enjoy the stiffer suspension. Never did enjoy how my machine "dove" while breaking into a turn.
2010 Sportsman 550 EFI
More mods to come.
atv coil spring compressor
atv coil spring spacer installation
coil on 2002 polaris sportsman 700
coil spring spacers on atv
extra large coil spring
hardened coil spring
how hard is is to change polaris sportsman springs to hd springs
how to change front springs on polaris atv
how to change springs on polaris
how to install coil spring spacer kit atv polaris
how to install polaris atv coil spring spacers
how to install struts on polaris atv
installing struts front polaris
polaris atv rope coil installation
polaris trailblazer coil install
replace polaris atv front hub coil
video of spring spacer for atv
where to install atv coil spring spacers
youtube.com how to replace a hubcoil on a 2002
youtube.com hubcoil for a 2002
2011 SP spring install Q's antoniodef ATV Brakes & Suspension 7 11-08-2011 07:28 AM
2002 Sportsman 2" coil spring spacer/strut plug forrest411 ATV Brakes & Suspension 3 04-26-2011 04:21 AM
Need a hub coil JoshH ATV Parts for Sale 2 01-27-2011 04:45 PM
help! broke spring oil pump spring! 96xpress400 ATV Repair and Maintenance 3 11-30-2010 07:35 AM
01 Sportsman Coil kit install sammy64 Polaris Sportsman 2 05-11-2010 12:38 PM
