08-10-2011, 05:28 PM
Member #17443
Coil spring install
I just got my rear HD springs and I'm looking for guidance regarding a DIY install. I'm brave enough to move forward on my own, but thought it best to ask for info first.
2005 Sportsman 700 EFI
Thanks in advance.
...the chrome won't get you home.
CNTRY
08-11-2011, 01:29 AM
Sorry man, I haven't done the rears yet... fronts where cake. I will likely be doing it soon... next week will tell.
08-11-2011, 07:51 AM
Member #5629
I'm sure that you can find a how to video on Youtube. I have seen one somewhere. It might have been a Highlifter video.
I know you can use rachet straps to do it. And they used 4 sets I think.
Good luck!
Con
08-11-2011, 08:57 AM
Member #9763
I have seen photos of the ratchet strap trick but i don't like the looks of it. You can go to Oriley's and rent the strut tool from them for free. Makes it go easier and safer.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
08-11-2011, 09:08 AM
Member #17443
Is a 'strut tool' the same thing as a coil spring compressor? I was going to pick one up this afternoon and do the install tonight.
Also, I'm wondering if I need to completely remove the shock or if I can get by with just disconnecting the top mount and swinging it out.
CNTRY
08-11-2011, 09:28 AM
Member #9763
They are the same. there are different styles but they do the same job. It's been a while since I did mine, but if I remember correctly you can just swing the top out. I'd have to look at mine when I get home to refresh my brain.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
08-11-2011, 11:56 AM
Member #13981
Danger (Ratchet Strap)
I wouldn't suggest the ratchet strap idea.They are very dangerous when it's time to release it.One poped loose on me when I was mounting tires after it began to seat the beed.It cut my wrist open,took (7) staples to close it up.There was a 1-1/2 gash in my wrist and 1/4 in. deep.You could see the tendon in my wrist.Like they say pay the deposit at O'Riley and do it safely.Ride hard,SAFETY FIRST,Mike
08-12-2011, 10:07 AM
Member #17443
After trying several compressors I ended up just taking the shocks and springs to the local powersports dealer. They called me an hour later and had the HD springs on the shocks. I'll finish up the install tonight. Thanks to everyone for their input.
@lost cause: the left-side shock can be done by just swinging it out...but I would'a had to remove the muffler to get the right-side one to swing out.
CNTRY
08-12-2011, 11:46 AM
Member #9763
Good to hear you got it tackled. It almost never goes as smooth as you would like it to. I remember removing the shock now because I also put the lift on along with the HD springs.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
08-24-2011, 01:56 PM
I hope you don't mind Gururror. It looks like your set, instead of another identical thread, I'll add to yours...
I'm doing my rears this weekend...
But I got started tonight...Gotta wait a couple days for the paint on my springs to harden... But I took maybe 30 minutes to get the shocks out, the old springs off them and everything cleaned ready for install of the springs.
Here is my bench and YES you NEED spring compressors!! I had to compress the springs a couple inches to get the keepers off, Then once I released the compression they grew a good 4" past the seated length! DO NOT TRY THIS WITH OUT COMPRESSORS!!
Here is everything out of the quad ready to be cleaned.
Here they are after some Simple green, a brush and some water...
I have to get the muffler off yet so I can clearance the fender bracket where it vibrates against the muffler.
Then as I said, I am painting the springs. I bought the High Lifter brand as they where in stock and 25$ cheaper than the EPI's. I would have spent the extra coin, but some here I believe said High Lifter doesn't make springs and has EPI make them for them... Only down side is the color... YELLOW! YUK... I have four coats of Rustoleum Hammered Blk paint on them. Come Saturday it should be sufficiently hardened not or mark too badly when I put the compressors on them...
atv coil spring compressor, atv coil spring spacer installation, coil on 2002 polaris sportsman 700, coil spring spacers on atv, extra large coil spring, hardened coil spring, how hard is is to change polaris sportsman springs to hd springs, how to change front springs on polaris atv, how to change springs on polaris, how to install coil spring spacer kit atv polaris, how to install polaris atv coil spring spacers, how to install struts on polaris atv, installing struts front polaris, polaris atv rope coil installation, polaris trailblazer coil install, replace polaris atv front hub coil, video of spring spacer for atv, where to install atv coil spring spacers, youtube.com how to replace a hubcoil on a 2002, youtube.com hubcoil for a 2002
