Old 08-14-2011, 08:45 AM
cwsartain's Avatar
Member #17691
Wanna run bigger tires on 08 Sportsman 500 H.O.
I just bought this 2008 500 thats in really good condition. Still looks brand new. Anyways, it has the aluminum wheels with 26's on it and I would like to either run 27s or 28s but it looks a larger tire will scrub the tie rod and the hub/strut. What is the work around for this? Is there a kit, or wheel spacers, or lift kit that will keep the front tires from rubbing?
Old 08-14-2011, 10:45 AM
bigblue78's Avatar
Member #17365
there are wheel spacers for the front to clear the struts.I put them on my 05 800 with 10 wide on the front and 12 on the back and no problem just needed a 1 inch spacer.goes good now.
Old 08-14-2011, 07:39 PM
Old 08-15-2011, 10:17 AM
lost cause's Avatar
Member #9763
Wheel spacers if you wanna run stock wheels or buy offset wheels.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Tags
lift kit, sportsman 500 h.o., tires
10 inch wide tires on polaris 500 ho
2008 polaris 500 wheel spacers
2008 polaris sportsman 500 big tire kit
big tire kits for polaris sportsman 500
big wheel kits on polaris sportsman
bigger tires on a 2011 polaris 500 ho
bigger tires polaris sportsman
installing bigger tires&rims with spacers on my 2008 sportsman 800
larger tires polaris sportsman 500 ho
polaris 500 ho wheel and tire package
polaris 500 sportsman rim options wider
polaris sportsman 500 ho wheel kit
polaris sportsman 500 wheel spacers
polaris sportsman bigger tires
polaris sportsman wide tires
sportsman 500 bigger tires
wheel spacers for 08 sportsman 500
wheel spacers sportsman 500
widest tires on polaris sportsman 500
99 Sportsman, analog speedo out with bigger tires?? 99_Sportsman335Olive Polaris Sportsman 1 06-16-2011 07:52 PM
Bigger tires on '09 XP 550 cwcooper85 ATV Wheels & Tires 17 04-22-2010 07:10 PM
2 stoke and bigger tires 88TB250 ATV General Discussion 4 04-05-2010 07:10 AM
bigger tires n2mudn ATV New Members 8 01-27-2010 04:55 AM
Bigger Tires Jamieg ATV Wheels & Tires 1 10-01-2009 05:32 PM
