Old 08-28-2011, 02:46 PM
Stretch's Avatar
Member #18111
2004 Sportsman 500 HO front question
Just bought this yesterday and noticed that the front sits about 2" lower than the rear, the rear sits at the same height as my neighbors 500 so i have to assume the front springs/shocks are worn out. My question is should I buy new springs, shocks or 2" lift and only put the front pieces on? Would like to fix this as cheaply as possible. Running the stock tires for now, might upgrade to a more aggresive tire but will stay with the 25" height. Wife is the main person that will be riding this so no need for 27" tires.
I'm in Denton, Tx btw.
Old 08-28-2011, 06:48 PM
Old 08-28-2011, 08:08 PM
Hawkeye 007's Avatar
Member #8077
Welcome aboard!! Does you shocks/springs have an adjusting cam on them? Adjusting it softens and stiffens your ride. It would raise and lower your bike some.
2011 Red Touring 850
Ricochet A-Arm guards
Old 08-28-2011, 10:03 PM
mstermechanic907's Avatar
Member #17047
Send a message via MSN to mstermechanic907
the cheapest way would be to add spring rubber spacers but i would change the shocks and springs.
Old 08-29-2011, 08:38 AM
Razorback's Avatar
Member #4649
That's just the typical front end sag. All the sportsmans do it. Get the HD springs and install them. $49.99 at the dealer for the set.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
Old 08-29-2011, 11:06 AM
lost cause's Avatar
Member #9763
HD springs or you could get just the spring spacers for a 2" lift for about the same price. Basically like putting a leveling kit on you truck.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 09-04-2011, 03:05 PM
Stretch's Avatar
Member #18111
Found the 2" lift on eBay for $40 with free shipping. Installed just the front components, looks great now and drives the same as it did before. Thanks for the advice.
04 sportsman 500 front differential problem
04 sportsman 500 ho front axle removal
2004 500 ho polaris atv review
2004 polaris 500 ho sportsman front suspension
2004 polaris 700 front axle removal
2004 polaris sportsman 500 front shock spacers
2004 polaris sportsman 500 front spring
2004 polaris sportsman 500 hd springs
2004 polaris sportsman 500 springs
2004 polaris sportsman or 2004.5 front hd spring
2004 polaris sportsman or 2004.5 front spring
2004.5 sportsman 500 front springs
2009 sportsman 500 ho front diff plug
adjusting suspension sportsman 2004
atv rubber sping spacers
front suspension on 2004 polaris 500ho atv
polaris 500 ho front axle removal
pure polaris front springs 2004
sportsman 500 2004 front differential
sportsman 500 pvc shock spacer
2004.5 Sportsman 500 front axle fillatre Polaris Sportsman 0 03-02-2011 07:32 AM
2004 Polaris sportsman 700 front gear box jeremey14 ATV Repair and Maintenance 1 01-04-2011 08:43 AM
2004 Sportsman 700 Front Diff plug thebigd ATV Repair and Maintenance 8 10-03-2010 10:52 AM
2004 Magnum 330 Sportsman Front End Problems beasleys ATV Repair and Maintenance 4 07-30-2010 01:25 PM
2004 Sportsman 500ho front axle bunker471 Polaris Sportsman 3 01-26-2010 03:08 PM
