Old 08-29-2011, 08:30 PM
BJones's Avatar
Member #18163
1995 sportsman brakes
Hello all, I recently bought 1995 400 sportsman 4x4. Can any explain to me how to bleed the brake system on these. There is no bleeder screw on rear set of calipers. Thanks in advance
Old 09-02-2011, 01:30 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
The parts diagram shows it on the top just inboard of the footbrake mechanical assy. Check to see if it hasn't been broken off. A caliper has to have a bleeder somewhere.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
1995 polaris caliper fits
1995 polaris rear brake caliper
1995 polaris rear brake diagram
1995 polaris sportsman 400 bleed brakes
1995 polaris sportsman 400..... how to bleed the brakes
95 polaris brake caliper
bleeding brakes 95 sportsman
bleeding polaris 400 sportsman brakes
brake adjustment sportsmen 400 95
how do you bleed the brakes on a polaris sportsman atv
how to bleed brakes on polaris 400l
how to bleed brakes polaris sportsman
how to bleed sportsman brakes
polaris 400 sportsman back breaks
polaris sportsman bleed brakes
polaris sportsman bleed breaks
polaris sportsman bleeding brakes
polaris sportsman brake bleeding
rear brake caliper 1995 polaris sportsman 4x4
sportsman polaris rear brake bleeding
1995 sportsman 400 Williamhartle ATV Repair and Maintenance 6 07-17-2011 12:59 PM
1995 Polaris Sportsman 400 4x4? hhcochris ATV Repair and Maintenance 5 01-03-2011 02:08 PM
1995 sportsman 400 4x4 problems GArider ATV Repair and Maintenance 8 11-09-2010 08:14 PM
1995 Sportsman 400 4X4 Bowen Polaris Sportsman 10 03-28-2010 06:11 PM
1995 sportsman 300 4x4 nd gas shut off s/w rickhise ATV Repair and Maintenance 3 02-28-2010 11:19 AM
