08-30-2011, 05:43 PM
Member #18194
CV Boot issue
2004 700 twin, right side outer boot problem, boot keeps tearing, has been replaced by dealer three times now. any ideas?
08-30-2011, 05:49 PM
Member #8077
Welcome to the forum! Maybe you need a-arm guards. What type of riding do you do?
2011 Red  Touring 850
Ricochet A-Arm guards
08-30-2011, 06:28 PM
Member #5629
Welcome!
Are you having a problem on the front or rear?
Do you have a lift on the bike?
I've had problems all summer with aftermarket boots. Finally used OEM boots and hopefully I have it under control.
Con
08-30-2011, 08:06 PM
Member #18194
Actually I dont think it's getting caught on any foreign matter (rocks, sticks.etc.) All high desert riding, exploring old mining towns in Northern Nevada. It is the right rear outboard and all three replacements have been OEM. Am now thinking about switching to Moose boots, No lift on the bike, all stock. Wondering if maybe there is an issuse with the CV that the dealer is over looking? Maybe the retaining clip that holds the shaft in place or something?
Thank you for the quick responses.
08-31-2011, 03:08 AM
Member #5629
Where is the boot ripping? If it's somewhere around where it goes thru the bearing carrier, it could be the clamp is rubbing and cutting the boot. Which may lead you to check the wheel bearing.
Con
08-31-2011, 03:59 AM
I agree if you dont think anything is hitting it there is something inside causing the damage.
I would do the job yourself looking for burrs or paying perticular attention for anything that could damage the boot.
It could even be damaged during assembly. Causing premature failire.
06 sportsman 800 cv boot keeps, polaris 2011 850 oem cv boot, polaris 850 cv boot
