Old 08-30-2011, 05:53 PM
trailblazerMMP04's Avatar
Member #18193
Exclamation 04 polaris trailblazer idle and rear brake issues
the rear brake on my o4 polaris trailblazer does nothing and it out wont idle and i tried adjusting the idle but its as far in as it can go so please help me figure these out please>
Old 08-30-2011, 08:23 PM
Old 08-31-2011, 03:16 AM
Member #18193
thanks
Old 08-31-2011, 04:03 AM
cwlongshot's Avatar
Welcome!
Get yourself some Sea Foam! Treat the fuel in the tank and see what it does after a couple tanks. Mix it 2oz per gallon.
For the brakes. Spray bleeders with penetrating oil. Change out the fluid. Bleed brakes and see what you get.
Old 08-31-2011, 04:54 AM
1M800's Avatar
Member #635
The rear master cylinder is junk on these. It was bad on ours when we bought it. I did some research on them trying to find a used one and it sounds like they go bad every couple years!
2005 Predator 500, Holeshot HD's, Pure Polaris slip on, 1" bar riser. (Mine)
2005 Sportsman 700 EFI, EPI clutch kit, Aaen megaphone muffler, 27" Highlifter Outlaws. (Mine)
2002 Sportsman 500 H.O. Remington Edition, 26" PXT's. (Wifes)
2001 Trailblazer 250 (Son #1)
2007 Phoenix 200 (Son #2)
2003 Predator 50 (Son #3)
Old 09-04-2011, 11:36 PM
btalon's Avatar
Member #18196
Is there an adjustment on the throttle for these? If you put a slight pressure on the throttle with your thumb, without actually revving it, it idles high while the idle adjustment screw is in all the way. When you let go of it, it gets lower and tries to kick up again, but dies. Running the sea foam through it. If that doesn't work, planning on rebuilding the carb.
Question on bleeding the brakes, there are 2 bleeders, not looking at it right now and I can't remember what one I was thinking for the rear pedal, is that the top one?
Old 09-18-2011, 12:45 PM
minidaredevil1999's Avatar
Member #18779
it could be the master cylinder, or the cable loosened. check the cable for tension and pull the master cylinder if the cable aint the problem. i just got one so i need to do work to it also. I'm no expert.
Old 09-18-2011, 02:26 PM
btalon's Avatar
Member #18196
I actually got the throttle adjusted and it idles great now, the brakes I was fiddling with and pulled the caliper off and the pads out, the pads were worn flat. I got new pads and put them in and for good measure bled the brakes and flushed the fluid with new fluid. The rear brake works like it's supposed to now. Won't lay a skid down, but will come close to locking the tires with the pedal. I did find the right bleeder was for the rear brake lever and used that one. I have a vacuum bleeder that worked great. My son kept the reservoir filled as I pulled fluid through it until it was clean and clear.
He is absolutely thrilled with the wheeler now, he was sort of discouraged it wouldn't idle and he had to keep pulling it to start it.
I'm going to move onto the starter next. The battery holds a slight charge, not enough to start it even after 24 hours of charge. I'm going to jump it from my truck to make sure it's not the starter and make sure it turns over with the key, if it does, I will replace the battery. I do have a jumpstart mode on the charger, might try that first.
Old 11-10-2011, 06:44 PM
the_goldser's Avatar
Member #20343
clean the carb,
i have an 04 trailblazer 250 and when i got my atv, it had been sitting for 3 years, and gas was left on. i cleaned the carb twice and went threw 3 cans of carb spray but i got it clean and clear and now it runs great. however i to am having the same issue with the rear break. does anyone know if there is a rebuild kit for the rear break?
Old 11-10-2011, 08:06 PM
btalon's Avatar
Member #18196
I believe I've seen some on ebay, haven't looked since I got it working. The pedal seems squishy again with it, I have to try bleeding it again to see if it helps.
Tags
idle problem, rear brakes, trailblazer problem
03 polaris trailblazer 250 brake bleeding
03 trailblazer idle noise
2000 polaris trailblazer idle adjustment
2001 polairs trailblazer break master cylinder
2001 polaris 250 break master
2001 polaris 250 trailblazer carb fast idle
2003 polaris trailblazer 250 brake problems
2003 polaris trailblazer 250 rear brake problems
brake lines for polaris trail blazer
ebay 2003 polaris 250 trailblazer master brake cylinder
how to bleed brakes on a polaris trailblazer
polaris 250 not idleing
polaris 250 trailblazer this break
polaris 400 trailblazer aux brake
polaris rear brakes problem
polaris trailblazer 250 throttle problems
polaris trailblazer atv rear brakes problems
polaris trailblazer brake problems
polaris trailblazer rear brake setup
polaris trailblazer rear brakes
2010 polaris 500 H.O idle issues makeshift13 ATV General Discussion 5 09-02-2011 10:54 AM
2000 Trailblazer 250 - removed and crimped brake line to rear brakes, now no front br usuallyresourceful ATV Brakes & Suspension 2 05-17-2011 06:56 PM
250 2stroke polaris trailblazer quad engine issues masterblaster Polaris Trail Blazer 29 01-28-2011 09:00 PM
broken brake lever/master cylinder on 06 polaris trailblazer tlowe1192 ATV Brakes & Suspension 1 09-04-2010 06:38 PM
2004 TrailBlazer Rear Brake Issue lpujml1 Polaris Trail Blazer 9 04-26-2010 05:28 PM
