Old 08-30-2011, 06:34 PM
blueridgerunner's Avatar
Member #15743
HD Replacement Springs
I have an 05 Sportsman that has spring sag in the front. I was looking into replacing them with HD springs but came across some comments on the boards that the HD springs caused handling problems. Would appreciate any experience anyone has with the HD springs. Would replacing with stock springs be better? What about spacers?
Thanks for your input.
Old 08-30-2011, 06:42 PM
racer37l's Avatar
Member #5629
You have several ways to go with this.
Install HD springs from Polaris, Highlifter, EPI, etc.
Or if you want to add ground clearance put a lift kit on the bike. These are available from Rubberdown Customs, Highlifter, Superatv, etc.
Or you could use spring spacers.
Con
Old 08-31-2011, 06:42 AM
Mike B's Avatar
Member #11566
Just finished putting HD springs in all four corners of my 2008 800 sportsman. The fronts made a huge improvment on handling IMO. I like a stiffer ride, the rears I did because my ATV would sit 2"-3" low with no rider or weight on it. I'm a bigger guy (6'3" 285 lbs) so I would bottom out on the stock springs, so I'm very happy with the improvments. Parts from Thor @ TheATVSuperStore.com: Polaris HD springs up front and EPI HD in the back . FYI for my 800 the fronts were very easy to install, the rears took alittle bit of time. Diffenently need a spring compressor to do the rears.
Mike B
Old 08-31-2011, 09:15 AM
cwlongshot's Avatar
Wink
Mike B
EXACTLY!! I couldnt agree more!!!!!
Im 6' 230 and love the ride with HD springs.
I have EPI HD up front and High Lifter HDs in rear!
There is a couple threads here reciently on this topic. Do a search maybe use my name to help. I added to a thread showing the complete rear spring swap. About a year back I did the same for the fronts.
No compressor needed for FRONT but defineately IS needed for rears.
Old 08-31-2011, 09:25 AM
lost cause's Avatar
Member #9763
You may notice the ride become a little stiffer but it will not negatively affect your handeling.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 09-02-2011, 08:57 AM
Member #15743
Thanks for all of the feedback. Will definitely put the HDs on.
Old 09-02-2011, 11:17 AM
guruerror's Avatar
Member #17443
I did EPIs on the rear and would definitely like to hear feedback from you regarding your fronts once you get them on.
...the chrome won't get you home.
CNTRY
Old 09-02-2011, 11:38 AM
Mike B's Avatar
Member #11566
Like I mentioned, I did front and rear, the front was a huge improvement in handling.
Old 09-02-2011, 01:57 PM
kool_500HO's Avatar
Member #11710
I did highlifter HD's front and rear, huge improvment in handling, brake dive etc... Lost the comfy ride but I live with it... To many positive's
2011 Polaris Sportsman 500 HO
6000K HID's,Kimpex fender guards,foot pegs,rear seat,Polaris Front/Rear bumpers,2500lb winch,Handguards,ITP SS 12" 212 machined wheels,ITP Mudlite XL 26" tires,Highlifter springs Front/Rear,26" Outlaws,QSC clutch kit/Exhaust,UNI filter,Ricochet A-Arm guards...More coming soon...Kinda running out of stuff to buy though!
Old 09-02-2011, 02:41 PM
cwlongshot's Avatar
Mine also exibited much improved handeling. Less dive from brakes firmer more positive steering. Out back, far less squatting when you stab the tbrottle!!
2007 polaris 800 rear spring replacement
2007 polaris 800 sportsman stock or hd springs?
2007 sportsman 800 front suspension sag
2008 polaris sportsman hd springs reviews
2008 polaris sportsman replacement hd springs
800 sportsman front sag
front shock springs polaris sportsman epi
hd springs for polaris sportsman 800
hd springs for sportsman 800
hd springs on sportsman 800
heavy rear springs for polaris sportsman sag when towing
how to change spring on 2007 polaris 800
how to change springs on polaris
my sportsman front suspension sags
polaris sportsman replacement front springs
polaris sportsman replacement springs
rear springs for 2007 polaris 800
sportsman 800 replacement suspension springs
sportsman suspension sagging
spring spacer with high lifter spring
HD springs before and after Razorback ATV Brakes & Suspension 30 02-05-2012 03:37 AM
how can i tell the dif in springs hotairgypsy Polaris Sportsman 2 02-19-2011 10:05 PM
EPI HD Springs cityboy21 ATV Brakes & Suspension 1 02-10-2011 09:56 AM
shocks or springs 4winds ATV Brakes & Suspension 6 02-01-2011 04:17 PM
MV7 Springs Vinnie0918 ATV Brakes & Suspension 0 06-23-2010 06:02 PM
