Old 09-08-2011, 11:28 AM
cwsartain's Avatar
Member #17691
Lift Question
I have an 08 Sportsman 500 H.O. I bought a few months ago and I noticed that the front tires are towed in at the top. I researched it a little and found out that was normal for all Sportsmans, and to fix it, would have to get stiffer springs.
My question is, if I were to put a 1 or 2 inch lift on it, would that solve the problem?
Old 09-08-2011, 12:41 PM
Old 09-08-2011, 01:35 PM
Popo 500's Avatar
Member #10396
I put a RDC 2 inch lift in mine with the stock springs and now they sit perfectly level. I think if you do the lift plus heavy duty springs then they will be out more on the top then bottom.
2010 Sportsman 500HO
Big Gun Full Exhaust / Jet Kit / K&N
28" Zillas on SS212 Black / 2" RDC Lift
Front & Rear Rack Extension / Front & Rear Bumpers
Hand Guards / 3000lb Winch
HID with 3 Light Mod / Reverse Override
Wifes:
2002 Sportsman 400
Rear Rack Extension
Hand Guards
2000lb Winch
Old 09-08-2011, 01:40 PM
cwsartain's Avatar
Member #17691
Yeah I wasn't wanting to add HD springs. I was thinking about just added a lift and seeing if that took care of the problem.
Thanks!
Tags
lift
Question about a 2" lift for Polaris Sportsman NickS ATV Performance Modifications 39 01-02-2012 12:11 PM
Lift kit question SledRacer112 Polaris Sportsman 9 08-18-2011 03:50 PM
2003 Sportsman 700 Spring/Lift question SpartanTX117 ATV Brakes & Suspension 2 08-09-2011 11:29 AM
97 xpress 400 lift kit question buckshot276 ATV Repair and Maintenance 0 12-19-2010 11:07 AM
lift kit question CrazyFazy Polaris Sportsman 1 01-21-2010 08:49 PM
