Old 09-09-2011, 09:38 AM
Crash65's Avatar
Member #10187
lower front A arm 2011 sportsman 500 HO
Wife crashed the quad I may need to replace the front right lower a-arm on my 2011 Sportsman 500 HO the official Polaris parts list has 2202906 and 2202907 as “LH” anyone know which one is for the right side?
I was also wondering if I could just bend the arms back straight and run it as is – any thoughts on that?
thanks in advance
Old 09-09-2011, 10:25 AM
jordaman17's Avatar
Member #13240
probably be safer to have it replaced.
Old 09-11-2011, 04:02 AM
Member #1958
2202907 is the right hand a arm. The LH on both arms in the schematic is a typo.
If it's not bent very bad you can straighten it out and run it with no noticeable difference.
2008 polaris 500 a-arm compatibility
2011 polaris sportsman 500 ho a arm
2011 polaris sportsman arams
2011 sportsman 500 a arm guards
2011 sportsman 500 ho a arm guards
a arm for a polaris 500
front a arms 2011 polaris sportsman 500
left lower a arm for 08 polaris sportsman 500
lower a arm polaris 500
polaris 2202907
polaris 500 a arm sportsman
polaris 500 right lower aarm
polaris atv front a-arm 2000 sportsman
polaris atv lower front a - arm
polaris sportsman 500 a arm
polaris sportsman 500 a-arm repair
sportsman 500 control arm
straightening lower control arm polaris
where to put a 4 gallon fuel pack on a 2011 polaris 500 h.o. ?
wrong a arm rear of polaris sportsman'
'Load Out' for 2011 Sportsman 500HO front Box HU100 Polaris Sportsman 4 06-16-2011 03:21 PM
front brush guard for 2011 sportsman 500ho? solid_crimson Polaris Sportsman 1 04-22-2011 03:53 PM
2011 Sportsman 500 Front Diff oldjman Polaris Sportsman 0 02-01-2011 02:34 PM
Front lower control arm TRUCKSTRUCKMAN79 ATV Brakes & Suspension 2 10-06-2010 06:15 AM
Sportsman 800 rear lower arm issue... rotaxdave1 Polaris Sportsman 5 01-27-2010 04:10 PM
