09-24-2011, 09:21 PM
Member #18030
caliper rebuild
how do i get the pistons out of a 2001 400 scrambler rear brake caliper to install new seals/orings?
09-25-2011, 03:02 AM
I haven't rebuilt one in a ATV... yet. Cars can be a pia too there is a clip in some of them other screw in... dont know on the ATV sorry man. Maybe try a manual?
For what that's worth... (Just wanted you to know we are reading the post!)
Good luck,
09-25-2011, 04:48 AM
Member #1958
Take the caliper off the disc and mash the lever.
09-25-2011, 07:12 PM
Member #18030
thanks for help,got caliper and master cylinder seals out and new ones ordered...hope this fixes it!
09-26-2011, 07:09 PM
Member #7654
remove the caliper and the hoses and use a air hose presure aply air to one of the hose hole and hold the piston of the calper and apply air to push it out make sure that the brake fluid is out of it or you will make a big mess
04 scrambler leaking brake fluid out of rear caliper, 2000 polaris 325 trail boss rear caliper used for sale, 2000 polaris expedition 325 brake caliper rebuild kit, how to change rear brake caliper on atv, how to fix atv caliper brakes, how to install a caliper rebuild kit on a atv, how to rebuild a atv brake calipers polaris, how to rebuild polaris brake caliper, how to replace polaris caliper seals, polaris 325 rear calpier, polaris callipers rebuild, polaris front brake caliper remanufactured, polaris rear caliper rebuild kit, polaris scrambler front brake rebuild, rebuild polaris caliper, rebuild polaris rear caliper, rebuilding a 2001 polaris 500 rear brake caliper, rebuilding polaris magnum brake caliper, rebuilding polaris rear brake caliper, removing piston from polaris magnum brake caliper
