Old 10-01-2011, 03:28 AM
killshot's Avatar
Member #19172
99 polaris 400 scrambler brake poblems
i've just bought this wheeler a couple weeks ago and been working on it .my main problem is when i try bleeding the brakes when i pump the brakes using the main master cylinder fluid comes out the rear master cylinder .should i take the brake callipers apart and clean them completely or should i replace the rear cylinder the rear brake pedal has no back pressure at all and neither does the front .
im wondering if my rear caliper is getting bleed by .the front brakes try to work but the rear doesnt move at all .
has anyone else had this problem
plus when i got the wheeler the front master cylinder was dry .the old fluid that was in the lines was rusty colored and i've been pumping the system and replacing it with new fluids i have gotten all the old fluid out and its clear colored now .
Old 10-01-2011, 04:29 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
Hand and foot brake are two separate systems acting on a stepped piston at the rear. Your rear caliper seals are shot. Check the stepped piston as it might be scored. I would dismantle all the calipers and clean/replace pistons and seals as necessary.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
Old 10-01-2011, 04:54 AM
cwlongshot's Avatar
Wink
I agree, the two systems "meet" in the rear caliper. Otherwise they are seperate. Thats where you need to look!
Old 10-02-2011, 06:04 AM
killshot's Avatar
Member #19172
thanks ill do that
04 scrambler leaking brake fluid out of rear caliper
99 polaris atv
atv parts 400scrambler
how to adjust polaris scrambler brakes
how to bleed polaris scramblrr brakes
how to bleed scrambler 400 brakes
how to bleed scrambler brakes
how to bleed the front brakea on a 400 scrambler
how to change a 99 polaris scrambler front brakes
how to fix back brakes on polaric scrambler
polaris 400 brake problems
polaris brake problems
polaris brake problems caliper or master cylinder
polaris scrambler rear master cylinder problem
rear brake adjustment on a polaris scrambler 400
rear brakes for polaris scrambler
scrambler braking systems
why does my brake lock up on my 03 polaris scrambler
why does the brake fluid come out of the master cylinder on my polaris
scrambler 90 brake lights unclepudge Polaris Scrambler 3 02-28-2012 12:10 PM
Scrambler 400 brake question Ridge Polaris Scrambler 2 10-01-2011 03:32 AM
'09 Polaris 850 XP : replacement brake pads ripple ATV Brakes & Suspension 2 06-20-2011 04:43 PM
Scrambler brake problem pontiac69 Polaris Scrambler 1 04-04-2011 08:58 AM
WTB: 99 scrambler 400 lower rear brake bracket black06g85 ATV Parts for Sale 0 03-17-2010 03:40 AM
