Old 10-02-2011, 07:36 PM
cfm21's Avatar
Member #18030
Help,no rear brakes!
I have a 2001 400 scrambler i bought my son and can not get rear brakes to work.i bought all new orings and seals for caliper and master cylinder,rebuilt them both,cleaned them all out spotless,installed new brake pads and blew out brake line.bled with all new fluid,i am getting could firm pedal after bleeding and good solid stream of fluid out bleeder,but when on jack stand,push pedal it will stop spinning wheel,but can turn wheel by hand and when riding it will not stop it at all,front is fine.going out of town riding thursday,looks as if he will have fronts only!
Old 10-02-2011, 08:03 PM
redrider022002's Avatar
Member #18580
do the rear brakes work any better with the hand lever? it should control front and rear simultaneously.
2000 scrambler 400 2 stroke 2wd (stock)
2006 scrambler 500 4wd (stock)
2007 scrambler 500 4wd (stock)
2012 scrambler 500 4wd (stock)
Old 10-02-2011, 08:36 PM
cfm21's Avatar
Member #18030
no they do not work with lever either
Old 10-03-2011, 01:10 AM
SMP63's Avatar
Member #13545
Sounds like there is still air in the lines. I would try to bleed them some more.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 10-03-2011, 04:02 AM
cfm21's Avatar
Member #18030
any bleeding tips?bought vaccum pump and none of the 5 tips will stay on little bleeder valve on quad{it is to small}so getting my money back for that today.i have been pumping,holding,crack bleeder,close,letoff pedal for 20 minutes at a time prob.15 times over last week!what other tips,tricks anyone got?thanks!
Old 12-19-2011, 07:57 PM
DeeRector's Avatar
Member #21480
IM having the same issue. I brought it to Polaris 2 times. After the worked on it extensively for 6 weeks in total, I get the quad back and the breaks still don't work. When I jack the bike up and rev it, the breaks do indeed stop the rear from spinning. But when its on the ground and your moving, theres just way too much force to bring the quad to a slow down. Also, when you do use the break, you need to put all your weight on the pedal to engage breaks. Im 190lbs and if I hit the break while sitting, I get zero slow down. When I stand I probably get about 30% slow down, but impossible to lock the rear up and skid. Any thoughts?
Old 12-20-2011, 04:00 PM
sman700's Avatar
Member #12597
The best bet is to try and make the vacuum bleeder work. I had the same problem with the rear brake on my sportsman and kept bleeding it by hand but had no results. Used a vacuum bleeder and I can lock up the rear brake while riding now.
Old 12-20-2011, 06:48 PM
bakada's Avatar
Member #2821
Try and find a vacuum bleeder with a small enough tip. Only one of my Polaris had any back brakes with the foot pedal only. After using the vacuum bleeder all three will lock the rear wheels.
Old 12-20-2011, 08:05 PM
DeeRector's Avatar
Member #21480
Any recommendations on what brand vacuum bleeder? Im going to try this next.
Old 12-20-2011, 08:10 PM
bakada's Avatar
Member #2821
I bought mine from Napa for about $25. It had a bunch of different size tips and the smallest fit.
04 polaris 700 rear brake pedal pump up then goes down
2001 polaris trailblazer brake bleeder
2001 scrambler 400 how to bleed rear
back brakes work when atv is stopped but when riding wont work
brake resevoir 400 scrambler
buy rear brake caliper for 2006 polaris scrambler 500
how to bleed polaris atv brakes
how to bleed rear brakes yamaha 350
how to bleed the brakes on a yamaha warrior 350
how to bleed the foot brakes on a polaris sportsman atv
how to do rear brakes on polaris
polaris 700 no rear brakes
polaris atv bleed rear brakes
polaris no rear brake
polaris scrambler 400 bleeding rear brake
polaris scrambler rear atv brakes dont work
rear brakes polaris atv
rear brakes wont bleed on polaris trailblazor
rear sportsman brake wont bleed
will mud make my scramblers back brakes not work
400/500HO 1 or 2 rear brakes?? WilliamBos Polaris Sportsman 1 12-19-2010 06:53 PM
Rear brakes Fatguy55 ATV General Discussion 3 05-18-2010 12:14 PM
99' Scrammie no rear brakes ??? GHayduke Polaris Scrambler 5 05-12-2010 06:30 AM
Rear Brakes on 09 and 10 sportsman 850 slyder01 Polaris Sportsman 7 03-19-2010 02:57 PM
Brakes and rear suspension justincsandbar ATV Brakes & Suspension 4 11-02-2009 11:58 AM
