10-04-2011, 02:53 PM
Member #19069
tire size?
I have a 2011 550 X2 and Im wanting to run a bigger tire than stock, what is the biggest I can go without lifting it?
2011 Sportsman 550 X2,
factory Polaris 2500# winch,
otherwise stock for now,
Duro power grips on the back, soon to be all around.
bumpers soon to come,
skid plates soon to come,
big gun exhuast, Uni filter, and clutch adjustments soon....
10-04-2011, 05:09 PM
Member #5629
The largest I would go is 28"! But, as you go larger with the tires, you also will have to consider a clutch kit and heavier axles. This will depend on how you ride and where you ride.
Most of the time you could go one size larger and have little to no problems. However, the weight of the tire along with the height will have an impact on what else you'll have to do to the bike.
Con
10-04-2011, 05:54 PM
Member #10057
If you go bigger at all, you'll probably run into the "rubbing the bracket" issue that has been discussed here in the past. Can't remember what part of the forum that was discussed in, sorry.
I have a 2011 550 X2 as well and finding tires looks as though it might be an issue- without significant modifications that I am not willing to make ($$$ and it seems as I watch others, more mods=more problems).
Ricochet Ultimate Armor
2005 Honda Rancher 400
2005 Honda Recon
10-04-2011, 06:01 PM
Member #10057
From what other X2 and Touring owners have said, 28's will not work. Most have had issues with aftermarket tires that were listed as the same size as stock. Those specific tires actually measured a bit taller than stock though.
2005 Honda Recon
10-05-2011, 12:04 PM
Member #6457
Yea one of the other concerns is the tread pattern. With a really aggressive tread pattern i have noticed that more often that not they will require wheel spacers. Either way once you get up a couple inches in tire size you will get a few inches of lift of the machine also, so keep that in mind. A clutch kit would also be something to look into because the larger/heavier tires will effect the performance of the machine even if only slightly., if this machine were a 800/850 you would probably have a larger threshold before needing to mess with the clutch.
10-05-2011, 04:54 PM
Member #18518
Just thought I would let you know that I put 27 itp tires on and rub with a 2inch lift. looks like I will have to put wheel spacers on to stop the rub. My parts guy said they would work. I have a 2011 550 x2
2011 sportsman 550 efi
winch 2500 lb.
A arm rock guards FRT/REAR
I T P TIRES
highlifter
LOCK N RIDE GUN SCABBARD
10-05-2011, 05:37 PM
Member #8077
X2 and touring riders...until the aftermarket tire makers produce stock sizes 26x8 and 26x10x14 tires you're pretty much stuck with the Pitbull 25.5x8 and 25.5x10x14's, but that's not a bad thing because they are a top quality all around trail tire. There are probably none any better. You can go with larger and wider tires if you want to modify your atv. The width is the biggest problem with the aftermarket tires (26x9 and 26x11), that's where the rubbing issue starts. I have the Rockers myself. They are 8 ply where the Growler is 6 ply.
2011 Red  Touring 850
Ricochet A-Arm guards
10-06-2011, 04:03 PM
Member #18518
Hi Hawkeye mine don't rub on the sides it's when I hit bumps running about 25mph they hit on the inside fender wheel well where the footwell brace is for the passenger the highlifter kit works well but still have that small rub . I have itp tires that are 27 inch tall . I wish they were 26 though.
winch 2500 lb.
I T P TIRES
highlifter
10-06-2011, 04:58 PM
Member #19069
ok, I ride pretty hard and in rocks alot and love rock crawling so I dont want to lose my flexibility. So yall recommend stay with stock sizes? I put the stock size Duro Powergrips on and they rub.... Im getting wheel spacers for the back. I am also getting the clutch reworked for my altitude. I appreciate yalls input.
10-06-2011, 05:40 PM
Member #8077
Duro powergrip 26x8 and 26x10 14's are only 4 ply tires. That's pretty weak for hard riding and lots of rocks.
2007 tire size polaris sportsman 550, 2010 polaris 550 tire size, 2010 polaris 550 x2 maximum tire and wheel size, 2011 polaris sportsman 550 tire size, 2011 polaris sportsman tire sizes, 2011 stock sportsman 550 rim size, biggest tire 550 x2, biggest tire on stock 800efi, duro power grip weight, how heavy can i go with aftermarket tires before i need a clutch kit, itp tires on sportsman, lots of weight to balance heay atv itp duro powergrips, polaris sportsman 550 tire size, polaris sportsman tire size and weight, polaris sportsman x2 tire size, polaris sportsman x2 tires no lift, stock tire size polaris hawkeye, tire size for 2011 polaris sportsman 550, tire size for 2011 sportsman 550, what's the biggest size tire for a sportsman 550
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Help with tire size?
flht38 |
ATV Wheels & Tires |
5 |
08-21-2011 06:10 PM |
Which size Tire?
mudkicker |
Polaris Sportsman |
14 |
06-12-2011 04:23 AM |
tire size help
Sharkbait |
0 |
05-10-2010 07:25 AM |
what size tire
smiley |
3 |
04-22-2010 03:18 PM |
tire size
scott09 |
ATV General Discussion |
5 |
01-13-2010 09:15 AM |
