Old 10-08-2011, 02:27 PM
IndyRed800's Avatar
Member #19189
Spring Height
I went back 5 pages in this section browsing for spring questions along with performing a search and didn't come up with all my answers.
On my 2011 Sportsman 800 I can see that with a specialty tool I can adjust the pre-load settings on the rear of the bike. I cannot locate any such adjustment on the front struts? I'm i missing something?
Second is I purchase a Polaris Plow and 54" Blade and I have noticed Polaris are notorious for front spring sag. I'm interested in bolting on a set of Polaris HD springs or using Ranger springs?
Two questions: Do ranger springs fit front and rear and what year ranger should i purchase to fit my 11 Sportsman?
Second question: How much lift do Ranger springs offer compared to stock springs?
I've been told to purchase the 200# springs and not 250# because there are two types. I've also read the HD springs will put the bike back to factory specs in terms of lift but not really lift the bike much past the height it was designed for?
Everyone said the HD springs were a handling improvement and only harsher ride. Can the same be said for Ranger springs.
Thanks to anyone that can provide some information on all these questions.
Shawn
2011 Sportsman 800 EFI
Pure-Polaris 2500lbs Winch w/ 50' Amsteel Blue Synthetic Winch Rope, & UHMW Synthetic Roller Fairlead w/ Winch Saver
Pure-Polaris Lock & Ride Low Black Windshield
Pure-Polaris Lock & Ride Front Cargo Box
Pure-Polaris Glacier II Plow System w/ 52" Snow Blade
Pure-Polaris Sportsman Trailerable Cover
Old 10-08-2011, 02:42 PM
cwlongshot's Avatar
There is only adjustment to the REAR on these machines...
Unsure what model Ranger to use. But why not buy appropriate springs, specific to your machine?
The only "lift" with be in removing the sag from your current setup. If you grab and lift the front of your machine and carefully set it down this is how it will sit with any spring... It's as high as it can get. Same for the rear.
OMG, who ever told you 200 or 250# springs is WAY, WAY off base!!! The rear of two up machines, like the X2 are 140# rear springs... That's the heaviest offered in a Polaris ATV. The HD fronts are 100 or 105# IIRC...
Again I am not familiar with spring rates of ranger UTVs.
I have HD springs front and rear in my 700 and LOVE THEM!! I'm a bigger guy at 6' 230#.
Old 10-09-2011, 08:18 AM
IndyRed800's Avatar
Member #19189
I check documentation on spring rates on my 800 and they are 100 front and 110 Rear, so I hope the HD Springs are significantly stronger. I love the rides this Polaris has, although i'm not as big of a rider at 6' 205 it's perfect for me but the front has me worried come plow season. I'll check my local Polaris Dealer for Springs.
Shawn
Old 10-09-2011, 08:23 AM
IndyRed800's Avatar
Member #19189
HD Springs are 140 Non Progressive.
X2 Rear Springs are 130-150 Progressive
Figured I'd share some information I picked up.
Shawn
Old 10-09-2011, 05:25 PM
cwlongshot's Avatar
Here is mine, HD EPIs up front and HD Hi-Lifters out back...
BTW HD REARS may be 140# springs but the fronts are lighter...MAYBE 125# but if so that's max! (On a Sportsman!) I found out that Sportsman rear HD springs are on RZRs as a front... (The box my rear springs came in said so.)
Old 10-09-2011, 05:49 PM
antoniodef's Avatar
Member #11247
Polaris HD fronts lifted my 500 2" over stock springs. I did get some sag with my Polaris plow fully lifted on the stock springs. Haven't had the plow on with the HD springs to compare.
As far as HD rears, try stiffening the rear adjusters first. Mine are ridiculous rough riding when tightened, I can't imagine HDs.
2011 Trail Boss - HIDs SOLD
Old 10-10-2011, 03:42 PM
bottoms polaris's Avatar
Member #11730
Get some TM2 spring adjusters. Have them on mine and at bottom adjustment it sits level again with stock front springs. Rears r adjusted all the way up. If front sags with the plow it has 2 more levels of adjustment.
2009 sportsman 800,TM2 spring adjusters, rear springs adjusted to top position,28 inch swamp fox tires, SS 312 wheels,heavy duty tie rods and ends, viper 4500 lb winch,rear cargo box,homemade audio pipe ,ram mount drink holder. Trednecks.com Atv club
Tow vehicle,
2007 Dodge Ram Quad Cab,5.9 diesel 4x4, 7x18 double axle trailer
Old 10-10-2011, 05:13 PM
IndyRed800's Avatar
Member #19189
THanks to everyone that posted. I am going to go With HD Springs Front & Rear.
Shawn
Old 10-11-2011, 03:29 AM
cwlongshot's Avatar
Wink
Originally Posted by IndyRed800 View Post
Thanks to everyone that posted. I am going to go With HD Springs Front & Rear.
Good plan,
For the install, the fronts where cake. I didn't even need a compressor for them. BUT the rear... You must have a compressor! Read here... Coil spring install
Old 10-11-2011, 10:22 AM
IndyRed800's Avatar
Member #19189
Thanks for the link.
BTW next weekend coming up I will have a passenger and was thinking of bumping up the rear adjusters one notch. Could you tell me what kind of tool I need to turn the spring adjusters? I know I need to jack up the center of the bike to raise the rear tires off the ground, remove the wheels but after that i'm wondering how hard they are to turn?
Shawn
2000 polaris trail boss 325 front struts height interchange
2007 polaris sportsman 500 x2 rear springs
2009 polaris sportsman 800 x2 rear springs
250 trail boss strut installation spring compressor
fox struts on a 2011 polaris sportsman 800
heavy duty rear springs for 2010 sportsman 800
how to adjust rear springs on 2011 polaris sportsman 800
polaris predator front sag
polaris predator rear sag
polaris ranger rear spring interchange
polaris sportsman 800 hd springs or spring ajusters
polaris sportsman height adjustment
polaris sportsman rear height adjustment
polaris sportsman rear spring length
polaris suspension spring interchange
polaris x2 springs fit on sportsman 800
ranger springs on sportsman
trail boss 330 audiopipe
will polaris x2 rear springs fit 05 polaris sportsman 800
will polaris x2 springs fit a sportsman 500 efi
89 Trail Boss 250 Float Height and Pilot Screw Turns sickofit Polaris Trail Blazer 1 04-12-2011 09:43 AM
Need a spring raptormark Polaris Predator 1 03-10-2011 04:39 PM
2007 Trail Boss 330 float height mthomas ATV Repair and Maintenance 1 02-15-2011 01:38 PM
front shock height............. jroptop ATV Brakes & Suspension 5 01-25-2011 05:51 PM
help! broke spring oil pump spring! 96xpress400 ATV Repair and Maintenance 3 11-30-2010 07:35 AM
