Hello,
What model ATV are you working on?
01-06-2011, 08:10 AM
cwlongshot
I'm not sure. But it is straight forward. On my '07 I removed the front storage box allowing plenty of access. I set the front on a 5 gal pail with a block of wood. I mounted compressors to opposing sides of the spring and compressed it. Then removed top nut and assessembly from the top of the strut. Then removed the spring and carefully removed compressors. When comparing heights. I saw that thee was no pressure on the assessembly of my machine. So I mounted new spring and removed and installed other side without compressors. Yous could vary so do not just unbolt with out containing the coil spring. They could contain allot of pressure. And releasing them haphazardly could easily hurt someone.
