Old 10-17-2011, 03:10 PM
Gear_Head's Avatar
Member #14439
2002 scrambler front suspension
is too harsh for my wife. she liked the front suspension on her old xplorer better. Just starting my research, just curious if anyone had some ideas on how to soften it up. does not look to be adjustable.
Old 10-17-2011, 04:23 PM
redrider022002's Avatar
Member #18580
you're correct, the front isn't adjustable. have you tried softening up the rear spring for her?
2000 scrambler 400 2 stroke 2wd (stock)
2006 scrambler 500 4wd (stock)
2007 scrambler 500 4wd (stock)
2012 scrambler 500 4wd (stock)
Old 10-17-2011, 06:03 PM
Gear_Head's Avatar
Member #14439
yes. She could tell little difference. She doesn't push this things suspension to it's limits. She rode my father's rancher and liked how the softer front end felt, similar to her old xplorer.
I am looking into the possibility of swapping springs out of an xplorer.
Old 10-17-2011, 07:17 PM
Member #18580
ah I see. the scramblers are closer to a sport quad than the explorer, so the suspension is made to take a little more abuse. you may run into a bottoming out problem with softer springs. but if she doesn't ride too hard you should be ok though. someone on here should be able to give you spring dimensions for the explorer.
Old 10-18-2011, 01:27 PM
Gear_Head's Avatar
Member #14439
I am positive she won't bottom it out, if the dimensions are similar. I have been looking all over, have not found the length of the xplorers, yet.
03 scrambler 500 front springs
4wd atv front suspension
older polaris atv front suspension
polaris xplorer suspension
scrambler 500 better suspension
softening front suspension on polaris
Front suspension leaking air. Makavel07 ATV Brakes & Suspension 3 04-03-2012 04:28 PM
front suspension bushings for the 850 xp cvjoint Polaris XP 12 11-15-2010 03:20 PM
96 Sportsman Front Suspension uga1 Polaris Sportsman 2 09-25-2010 09:45 AM
cyclone front suspension CTcyclone ATV Brakes & Suspension 1 06-21-2010 05:10 AM
fRONT SUSPENSION ON 400 XPRESS 4X2 97 Jacob bo ATV New Members 4 02-20-2010 06:32 PM
