Old 10-18-2011, 10:00 PM
skind's Avatar
Member #19669
Question ? on front suspension w/plow
I have a 06 sportsman 500 with a 60" plow on it. I do not like how the front end sags with the weight of the plow. What do you all think of the Moose pregressor suspension preload adjusters that Dennis Kirk sells? I like the idea of an adjustment from stock without the plow to stiffer with the plow with out having to change the whole spring or adding a permanent spacer. Any pros or cons? Any other ideas? Thanks
Old 10-19-2011, 01:36 AM
cwlongshot's Avatar
Morning and welcome Hoosier!!
Some guys get the adjusters and seem to like them. They will lift the front by there thickness but do nothing for spring rate or capacity.
I prefer and went with HD springs in my 700 with a G2 60" plow and am very happy with them. its one of the best things I have done to my machine...
Old 10-19-2011, 01:41 AM
North Branch's Avatar
Member #1986
The adjusters will probably help some. However, everybody that put the Polaris HD springs on the front of their Sportsman seem to really like them... including me when I had them on my 500 HO. Really helped for plowing and for just general riding/handling without the plow.
Old 10-19-2011, 07:05 AM
skind's Avatar
Member #19669
Question
Ok. So you guys think the HD springs would be better. Do they make the front end sit higher? Do they make it ride a little stiffer or a lot? Would the Polaris brand be good enough or is the aftermarket better? Sorry for all the ?s. But thanks for the info.
atv plow front suspension
atv plow suspension
atv plow suspension sag
atv stiffer front suspension for plow
atv susoension lock
atv suspension lock
atv suspension lock for front
atv suspension plowing
do i need to modify my suspension for a plow on an atv?
front suspension help when adding a plow
front suspension on atv
is there a way to stiffen the front suspension on a atv with plow on
plow on atv added suspension
plow suspension on atv
polaris 500 atv front suspension sagging
polaris brand plow
polaris plow suspension
polaris quad front suspension
suspension setting for plowing polaris atv
utv plow lock front suspension
Front suspension leaking air. Makavel07 ATV Brakes & Suspension 3 04-03-2012 04:28 PM
Front suspension grease Montana Polaris Sportsman 12 07-28-2011 11:48 AM
96 Sportsman Front Suspension uga1 Polaris Sportsman 2 09-25-2010 09:45 AM
fRONT SUSPENSION ON 400 XPRESS 4X2 97 Jacob bo ATV New Members 4 02-20-2010 06:32 PM
Wtb suspension left front michalm5 ATV Parts for Sale 3 10-28-2009 07:22 PM
