Old 11-14-2011, 05:39 AM
dunnym1984's Avatar
Member #20435
need rear shock help
Hi,
I just picked up a 98 xplorer 400. The rear shock needs to be replaced. I have found a good deal on a used fox shock from a 2000 scrambler 400. Im wondering if anyone here knows if this shock will fit on my xplorer. I havent had much luck searching online about what polaris models share some of the same parts.
Any help much apreciated. Thanks
Old 11-14-2011, 07:02 AM
Old 11-14-2011, 09:24 AM
pjmartin's Avatar
Member #5074
Send a message via ICQ to pjmartin
Go to Browse
Find the shock in the parts diagrams. Expand the parts list column and you will see USAGE opposite each part. Click on USAGE and it gives you a list of models using the same part.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
2001 polaris rear shock
polaris xplorer rear shock
polaris xplorer rear shock fit polaris scrambler
polaris xplorer suspension
how do you adjust rear shock? bsmith0505 ATV Brakes & Suspension 2 05-05-2011 03:44 PM
will a scrambler 500 rear shock fit on a 500 predator rear? hunter51190@yahoo.com ATV Brakes & Suspension 1 10-18-2010 04:18 PM
rear shock swifty scrambler Polaris Scrambler 4 02-22-2010 01:36 PM
700 rear shock jonslink ATV General Discussion 6 02-16-2010 09:02 AM
96 rear shock djtates125 ATV Brakes & Suspension 3 01-08-2010 08:10 AM
