Old 11-21-2011, 06:09 AM
hillbilly2007's Avatar
Member #20644
X2 harsh ride!!!
Anyone know what springs/shocks I can upgrade to soften my rear suspension? It rides very rough even with 2 onboard. Preload adjusters are on the softest setting and all suspension bolts have been loosened and retorqued. Dont know what to do? Do I need to get another machine/brand to get a good ride? I had a 2007 sportsman prior and its ride was great I got this one to fill our 2UP needs. Its a 2006 sportsman X2 500.
PLEASE HELP all I can find are linkes to stronger srings?
Jeff
Old 11-21-2011, 07:29 AM
lost cause's Avatar
Member #9763
I have never heard of anyone complaining about the ride quality of a sportsman before. What year/model is it? Maybe a previous owner added stiffer springs and you need to get some stockers? Maybe your shocks are bad?
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 11-21-2011, 08:15 AM
Member #20644
Dont think springs have been changed on it color matches perfectly. Shocks are not leaking oil. Ride is not rough because it bottoms, ride is rough because it doesnt move very much even with me 215lbs and wife 140lbs on it. Only time I had a good ride on it was with the hind quarters of a moose in the box with #2 setting on springs. I think I just need softer springs, Ive heard use RZR springs ive heard use 08 and newer X2 springs but dont want to just buy without knowing spring rates for these and stock.
Old 11-21-2011, 08:17 AM
Member #20644
Ohh Yea Its a 2006 X2 500
Old 11-21-2011, 08:55 AM
rickcj7's Avatar
Member #5366
Yeah its stiffer to haul 2 person or 400 lbs in the bed.
You could buy some softer springs for the rear but you'd lose the weight carring capacity.
Running low air pressure in the rear tires helps alot never ran over 5psi in mine usually 3-4 psi.
Would the Touring rear springs be softer???
Old 11-21-2011, 09:00 AM
SMP63's Avatar
Member #13545
Welcome to the forum!! This is the first thread I've seen about them being too stiff. Agree with Lost Cause that they may be after market springs, sounds like they are HD springs.
Hopefully some 2up owners will tell you there opinion!!!!!!!!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 11-21-2011, 09:14 AM
rickcj7's Avatar
Member #5366
My X2, the front was too soft and the rear too stiff.
I installed SP 800 springs on the front to stiffen it up some.
I didn't really research the rear but SP 800 rear springs/shocks are differant.
My X2 did ride a lot stiffer than a regular Sportsman.
Old 11-21-2011, 09:25 AM
Member #20644
The front seems ok for now only 1400 miles on it but rear is too stiff. Would really like other springs for it, possibly touring? But dont want to just buy them to find they are the same spring? Does anyone know the wire diameter on a HD spring vs stock rear could I check this way to see what mine are for sure? Thanks a bunch for any info dealers here dont want to be bothered with this kind of thing they just want to sell big dollar machines.
Old 11-21-2011, 09:35 AM
lost cause's Avatar
Member #9763
I don't know for sure, but I would imagine that the touring springs would be softer and the regular sportsman 1up would be even softer. Maybe you could find some used one's for cheap. I have the stockers off my 800 that have less than 5 hours on them but I don't know about shipping to canada.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N FILTER
POLARIS 3500 WINCH
Old 11-21-2011, 09:54 AM
Member #20644
Touring would probably work I will bug the dealer tomorrow, If I knew the spring rate on mine all I would need is the spring rate on aftermarket and dimensions which should be easy enough to get.
2006 sportsman x2 back rack
2007 polaris sportsman 500 x2 rear rack
2007 polaris sportsman x2 rear rack
2007 polaris sportsman x2 spring spacers
hd springs for polaris x2
polaris sportsman x2 stiff rear
polaris x2 rack
polaris x2 rear rack
polaris x2 rear springs
polaris x2 sprimg spacers
preload on polaris x2
softer rear springs for polaris sportsman atv
softer springs for x2 polaris
sportsman x2 stiffer springs
sportsman x2 suspension springs
x2
Very harsh takeoff? chirojh Polaris XP 4 11-06-2011 03:46 PM
I don't get it.. How do you ride? SportsmanJohn500 Around The Garage 43 08-19-2011 11:53 AM
550 XP Harsh clutch engagement fix Thomasj Polaris XP 11 08-07-2011 09:55 AM
new ride 2010XP850EPS Polaris XP 18 05-20-2010 05:22 PM
my first ride on my 300 2x4 bomberboat ATV General Discussion 3 12-27-2009 07:48 AM
