Old 11-22-2011, 12:05 AM
chuckinnc's Avatar
Member #16681
Installing front springs on X2
I want to install a HD set of front springs on my 07-800 X2. Has anyone done
this? I have a used set without instructions, I have seen various you tube and
websites for installing them on a regular sportsman, but the X2 can sometimes
be a different animal. Is there a wibesite for installing them on a X2 anywhere?
07 Sportsman 800 X2 EFI
27" Mudlites on 14" ITP
everything else stock
Old 11-22-2011, 01:43 AM
cwlongshot's Avatar
I dont see why they would be any different... the vast majority of the diferences in the X2 are out back....
On my 700 I did not even need a compressor. (FOR THE FRONT!) Its a easy job, if your conserned many auto parts stores will loan a set of compressors for little or nothing.
Remove your front box and lid and you will see you have plenty of access to the top nuts. Once loose they tip out allowing the springs removal. If you search the topic with my screen name the tipoc should come up for you to see my pics.
polaris x2 front springs
polaris x2 rear springs
x2
Want HD front springs, which ones? redneckff42 ATV Brakes & Suspension 10 12-12-2011 05:06 PM
Installing front and rear brush guards on a Sportsman 800 GhostOps Polaris Sportsman 4 04-05-2011 04:52 PM
installing clutch springs jma3082 ATV Performance Modifications 6 04-02-2011 09:23 AM
HD Front Springs? duffer ATV Brakes & Suspension 13 02-12-2011 11:22 AM
Installing polaris front a-arm guard on 850 xp BTH Polaris XP 0 05-15-2010 11:40 AM
