Old 12-16-2011, 12:38 PM
Beef's Avatar
Member #21158
Question 97 xplorer rear shock replacement
The rear shock on my xplorer 300 is completely shot you came push the bike down with one finger. I am currently reseaching my options ihave found replacement shocks for about 80 bucks oem for about 120 bucks used on ebay complete with springs any were from 15 to 100 bucks. inotice in factory specs that the xplorer 400 has larger diameter shock 1 3/8'' opposed to 1'' for the 300. im a bigger guy and am trying to figure out if a 400 shock would bolt up on a three hundred ? does the 400 have more damping? are the springs heavier? woul i be better of just buying a new replacement?
polaris explorer rear shocks
polaris shock replacement
polaris xplorer 300 rear chain specifications
polaris xplorer 300 rear shock
polaris xplorer rear shock
rear shock for polaris xplorer
rear shock on my polaris xplorer
rear shock polaris explorer ebay new
rear shock polaris xplorer
shocks 97 xplorer 500
xplorer 400 rear shock
xplorer drive chain replacement thepopeis1 ATV Repair and Maintenance 11 03-15-2012 09:12 PM
2007 Sportsman 500 X2 Front Shock Replacement Driveitlikeyoustoleit ATV Brakes & Suspension 1 08-25-2011 03:58 PM
will a scrambler 500 rear shock fit on a 500 predator rear? hunter51190@yahoo.com ATV Brakes & Suspension 1 10-18-2010 04:18 PM
Xplorer 300 rear shock rockinkgin ATV Repair and Maintenance 4 07-15-2010 06:44 PM
98 Xplorer will not run after main bearing replacement Palmetto Polaris ATV Repair and Maintenance 7 05-30-2010 01:46 PM
