12-23-2011, 02:32 PM
Member #21515
05 sportsman front lower ball joint removal
im trying to replace the front axle bearings and im struggling with the lower control arm joint, do i need a pickle fork ? i have one for a car but not a small one to fit this bike. whats the best way to seperate this joint? thanks all
12-23-2011, 02:40 PM
Member #21515
i guess i dont need to remove the joint just seperate it from the a arm its tight . should i try heat?
12-23-2011, 05:22 PM
Member #1234
Usually a couple hits with a hammer on the knuckle of the control arm and it seperates,but i have used a car pickle fork too,just be careful not to rip the grease seal.
12-25-2011, 05:03 AM
I use 2 hammers, hold one on the a-arm by joint and hit it hard with another , large hammer
2002 sportsman front control arm removal, atv ball joint replacment, how to change ball joints on polaris sportsman 500, how to remove lower ball joint polaris sportsman, how to replace ball joints in sportsman 500, how to replace polaris lower ball joint sportsman, how to replace sportsman front ball joints, polaris atv how to remove the ball joints, polaris ball joint removal, polaris ball joint removal#gsc.tab, polaris balljoint removal, polaris lower ball joint tool, polaris sportsman ball joint removal, remove balljoint from sportsman, removing a lower ball joint on a atv, removing lower ball joint on polaris, replace polaris lower ball joint, sportsman 500 ball joint removal tool, sportsman lower ball joint, sportsmans lower ball joints
