Old 12-28-2011, 06:19 PM
SpartanTX117's Avatar
Member #3503
Lift/HD Springs
I have a 03 Sportsman 700. I currently have EPI HD rear springs installed. I have a set for the front but have been debating about installing the 2 in Highlifter lift kit I have and taking off the HD springs. I have also though about leaving the HD spring on and adding the lift but was told I would definatly have axle issues. I am really not wanting axle problems. Does anyone have any insight on this? I am wanting it to look meaner but not if I'm going to have major issues. Thanks. Also if it matters I have a stock clutch and 26in Swamp Lites.
Old 01-03-2012, 03:40 AM
lost cause's Avatar
Member #9763
You may or may not have axle issues with the lift. My buddy currently owns a 2004 700 with the highlifter lift and HD springs. He breaks the same axle every other ride. Any time you change the angle of the axles you are asking for axle problems. It does depend on your riding style as well. If you are going to be simple trail riding with small tires then you will most likely be ok with the lift. If you plan on getting into the mud or off camber situations, you will most likely break an axle. In short, I would plan on replacing your axles if you plan on lifting with the HD springs. As for the swamp lites, you will not need a clutch kit. Just make sure you know when to use low.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
atv hd springs
hd springs
Upgraded Springs or Lift Kit??? UnityH8r ATV General Discussion 14 07-10-2011 08:06 AM
2" lift and HD Springs ? Installed v10rock ATV Brakes & Suspension 33 04-23-2011 09:30 AM
lift or springs? fendersquire ATV Performance Modifications 8 04-02-2011 11:36 AM
how can i tell the dif in springs hotairgypsy Polaris Sportsman 2 02-19-2011 10:05 PM
EPI HD Springs cityboy21 ATV Brakes & Suspension 1 02-10-2011 09:56 AM
