01-02-2012, 02:53 PM
Member #19481
Spring spacers
I recently installed a set of the pure Polaris rubber spring spacers due to the front end sagging a little after a winch and brush guard. After installing them I noticed that they aren't tight at all. You can still move them even while on the bike. Is this normal? If so, maybe they're not needed. Insight please.
01-02-2012, 03:30 PM
Member #14032
They are mainly designed to be used with a plow attached to the bike. But if you get some industrial zip ties and place a few around them to help hold them in you could use them all the time.
I got some for my dads 600 because he is not a big mod junkie like most of us can be. Turning and general use has made it easier for the steering with him. While running the plow they help some...but springs would have been better.
Overall...yeah they are good for basic apps...but not hardcore use.
Matt
Mine:
2011 Sportsman 800
Polaris Front Brush Guard, Polaris Rear Brush Guard, Polaris Rear Rack Extender, Polaris L&R Rear Cargo Box, Warn 2500lb winch, Winch Saver, Ricochet A-Arm Guards ( www.TheATVSuperStore.com), 3-High Headlight Mod, UNI Air Filter, 26" GBC Dirt Commanders, 1" Billet Wheel Spacers (Front and Rear) HighLifter HD springs, Dalton Primary Spring O\BL, Realtree Seat custom cover
Wife's
2011 Sportsman 550XP
Polaris Front Brush Guard, Polaris Rear Brush Guards, Polaris Rear Rack Extender, 26" GBC Grim Reapers, Viper Elite 3000lbs Winch w/ wireless
Fuel It, Flog It, Feel It!
01-02-2012, 03:31 PM
Member #14032
Almost forgot...they will help with the front end diveing when hard braking is needed.
Matt
Mine:
2011 Sportsman 800
Wife's
01-03-2012, 06:44 AM
Member #19481
Do you think they will come out if I dont zip tie them in?
atv plow spring spacers, atv rear spring spacers, atv rubber spring spacers, atv spring spacer, atv spring spacers, atv suspension springs spacers, billet spring spacer atv, front end spacers polaris sportsman, how to install atv shock spacers, polaris front spacer, polaris front spring spacers, polaris rubber spring, polaris rubber spring spacers, polaris sportsman front spring spacers, polaris sportsman spring spacers, polaris spring spacer, polaris spring spacers, rubber spring spacers for atvs, sportsman front spring spacers, spring spacer
