01-03-2012, 06:21 AM
Member #21916
sportsman 500 1999
My master cylinder on handlebar keeps pressurizing and locking my brakes up. I then let fluid out and it is ok for awhile but then prressure builds up again and handle and brakes are locked up again. what should I check to be the problem. Could it be the master cylinder itself or a different part of the braking system?
01-03-2012, 07:33 AM
Member #5074
There is a compensation port at the bottom of the reservoir and a vent port above the diaphragm. If these are blocked the fluid can't come back into the reservoir when the lever is released.
2001 Sportsman 500HO
Rear drop rack
2000lb winch
No mods
01-03-2012, 04:35 PM
01-07-2012, 12:48 AM
Member #21916
Thanks for advice, checked the ports and they seem to be free. I am ordering a new mastwrcylinder, hopefully that will clear it up.
01-07-2012, 04:57 AM
Member #3687
I agree with pjmartin. Vent stopped up on the master cylinder cover. Make sure to use good clean brake fluid. Over a short period of time brake fluid draws moisture. Water in brake fluid will cause a problem. If brake fluid is dirty drain what you can by loosening lines or bleeder screws. Starting with the right front brake,try bleeding the brakes. They brakes are sometimes hard to bleed. If you have trouble bleeding them try this with the master cylinder empty ans the cover off: Use a squirt oil can(Metal hand held pump oil can) with a metal spout and a piece of hose on it. Barely loosen the bleeder screw, attach hose and start pumping. This will fill the master cylinder and you will be able to bleed the brakes easier. I hope you find the cause of your problem.
01 sportsman fluids, 1999 polaris sportsman 500, 99 poraris sportsman brakes locking, bleed brakes on polaris 500 sportsman, brake bleeding polaris 500, brakes locked up on polaris sportsman 500, how to bleed brakes on a 1999 polaris sportmans 500, how to bleed brakes on a polaris sportsman 1999, how to bleed brakes polaris sportsman, how to bleed polaris atv brakes, how to check my cylinder on 2012 polaris sportsman 500, my sportsman is locked up, polaris 2000 sportsman 500 4x4 back brakes trying to lock up, polaris 500 sportsman brake bleed, polaris master cyl. break lock up, polaris sportsman 500 brake, polaris sportsman 500 brakes keep locking, polaris sportsman 500 brakes locking, rear master cylinder for a 1999 sportsmen, sportsman 500 brake
