01-06-2012, 06:51 PM
Member #12721
suspension problem in rear
I have a 2011 polaris sportsman 500ho and I am a little concerned with my rear suspension. I have not even a 150 miles on it but what's happening is when I get on it I can feel the suspension go down a bit which is normal. What concerns me is when I get off it doesn't recoil or let me better say this... rise back up to where is should be. Should I be concerned or is this normal. I don't do any hard riding period. It rises back up but not much. And I can walk to the rear of the atv and pull up on the back and it moves up about 2 to 3 inches. What do u guys think?
01-06-2012, 07:05 PM
Member #12721
Could it be that my shocks need to be adjusted
01-06-2012, 07:40 PM
Member #13545
Is the wheeler still under the 6 month warranty? Both our wheelers spring all the way back up whe we get off them. About 1500 miles on the red & 2500 on the green. I think theres a problem some where in the rear suspention. You could try to turn up the spring adjusters on it but you shouldn't have to.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
01-06-2012, 07:43 PM
Member #12721
No I bought in feb of last year. How could I adjust it.
01-06-2012, 08:13 PM
Member #13545
If you look at the bottom of the springs you'll see an aluminum piece that the springs sit on. It will have notches in it right under the spring & then alittle further down @ the bottom of the adjuster you will see that it has steps in it. As you turn the adjuster it will raise the preload on the springs. They make a special wrench for this but most use a large pair of channel locks. You need to jack the back of the wheeler up to take the weight off the springs making it easier to turn the adjusters (wouldn't hurt to give them a good spray of WD-40), most also remove rear tires to give easier access & have more room to do this. I would turn them up 2 steps to begin with.
2500# polaris winch
Rev. override kit
Hid 3 light kit
Wifes
Hid 3 light kit
01-06-2012, 08:32 PM
Member #12721
Well I just checked it for sure. When I pick up on the back and lift up til it is at its highest point. From the bottom of the hitch to the ground it measures 15 inches. I rode it for a sec and around the yard ... got off and measured it without lifting up on it. Itb was almost an inch less . Little above 14 inches. I don't think it used to be this way.
01-06-2012, 08:39 PM
Member #13545
It should spring back up for only having 150 miles on it!!. Try turning up the spring adjusters.
2500# polaris winch
Rev. override kit
Hid 3 light kit
Wifes
Hid 3 light kit
01-06-2012, 08:49 PM
Member #12721
Is it possible the spring adjusters could have moved
01-06-2012, 11:09 PM
Member #13545
They come from the factory on the lowest setting.
2500# polaris winch
Rev. override kit
Hid 3 light kit
Wifes
Hid 3 light kit
01-06-2012, 11:47 PM
Member #12721
So basically something is screwed up
difference in rear shock on polaris sportsman and xplorer, home made lift kit for mac struts polaris xplorer, how to turn spring adjusters polaris, polaris predator front sag, polaris predator rear shock trouble, polaris rear suspension problems, polaris sportmans rear sagging, polaris sportsman 500 rear suspension problems, polaris sportsman 500 sags, polaris sportsman rear shock, polaris sportsman sagging rear, polaris sportsman suspension problem, polaris sportsman suspension sagging, sagging rear shock for sportsman 500, sportsman rear suspension dont move, sportsman suspension sagging, stiffen rear suspension on a polaris sportsman 500, suspention problems with polaris sportsmans, why is my back suspension way to soft on polaris sportsamn, will a 2001 shock in spring she is a 2006 polaris sportsman 500
